How often add water to radiator?
ranii
, Jul 01 2004 01:54 PM, 67 replies to this topic
Posted 01 July 2004 - 01:54 PM
Up till now, I hardly need to top up the radiator coolant in my Wira
1.5A. My wira almost 5 years old. Recently I noticed that the temperature
gauge shot up. When I checked, my coolant level was very low.
I don't see any leak. Where did the water go?
Should I just top up the water and forget about it , or should I change
the hoses etc etc?
the hoses etc etc?
Posted 01 July 2004 - 02:50 PM
ranii,
Have you car encounter overheat problem before this ?
If yes i am suspecting it could be due to your cylinder head overheated
and got "bengkok"...
Aside from that, do check your water pump and radiator as well..sometime
the small leak can end up with bog problem wherebu you won't notice the
leak as your car move or the hot air from your engine bay dried the water
leakage spot
leakage spot
Posted 01 July 2004 - 02:58 PM
"the hot air from your engine bay dried the water leakage spot" - g88 -
That's what I told someone sometime ago about the possible leakage. You
wont be able to observe it until it's to servere. Unless you coolant is
light colored, then some marks will be left on the leakage spot. Anyway,
if it rains, these spot might get washed-away by the rain droplets coming-
in from the radiator.
Sometimes if the leakage occurs only when the engine is running
(pressure). So ranii, if this happens again, better get your radiator and
the hoses checked. Dun forget the container too!
Hope this helps.
Oh! Gosh! I haven't touch all the "fluids" in my engine until today... 2
months already...
Hope this helps.
months already...
Posted 01 July 2004 - 05:49 PM
Thanks sifus.
Never experience overheat before.
First time only bcos fluids dry already and I wasn't aware.
But dunno where the fluid have gone.
Will send in to check if fluids dry again.
Posted 02 July 2004 - 05:37 PM
ranii,
when u back home from a drive, park yr car safely and with the engine
still running, open up the bonnet and look again for any leakeage. just
look! dont touch anything or come close to the fans! with the engine hot
and running, u may have a better chance to find the leakage unless its not
too severe just like what drexchan had said.
if after a while u dont see any leakage, turn off the engine and put plain
paper like 'kertas mahjong' on the floor underneath the engine and leave
it overnight. the next morning, reverse yr car and examine the paper and
see if u can find any spot of coolant on it (u can tell by its color).
identify which part on the paper the spot is.
Posted 03 July 2004 - 12:55 AM
it could be the O -ring. ..the one which is on the radiator ...
i mean the radiator top(not a small O ring , the whole top) ...can check
any small leakage at the side of the top cover ... last time my car oso
encounter such problem
Posted 03 July 2004 - 11:33 PM
oh last time i hav also encounter with few kinds of increase in water
temp. Very headache oso cause need to check alot of stuff to find the
culprit, so u need patience. Actually if u notice the spare water tank
decrease in water level then u need to add in water there but sometimes u
oso need to open up the radiator cap to double check it cause afraid of
any blockage between the radiator n the spare tank.
2nd thingy is the water pump leakage, as they said when the leakage is
not that critical u need time to check n do what they reckon u earlier.
3rd thingy is after driving for sometime, stop ur car n open up ur bonet
wait n c whether the fan is working or not.
4th thingy is if all the above not the culprit then i think u need to
flush ur radiator.
Please correct me if i'm wrong.
flush ur radiator.
