How much new ignition cables?
g88
Posted 25 September 2004 - 02:54 AM
g88
    Duke of Hazzard
  • PipPipPipPipPipPipPip
  • 48,280 posts
yinho,
the high tention cable you refering to izzit the thickness of the cable
like 10mm or 12mm those kinda of cable ?
Well it's not recommeded for you to use oversize cable...FC will increase
since you will gain slight more power as sparking more to you piston and
higher combustion but then i ever saw ppl end up piston lubang becoz of
the strong spark "fire" from thick cable
kitkat80
Posted 25 September 2004 - 09:09 AM
kitkat80
    Hot Rod
  • PipPipPipPip
  • 10,646 posts
g88, the slight gain of power i believe is from the more complete
combustion of the fuel due to mroe powerful sparks...however...if the
driver kaki mantain...FC should not increase....becoz the amount of fuel is
still the same....u can ask emanage to clarify this.
Emanage
Posted 25 September 2004 - 02:20 PM
Emanage
  • 4,698 posts
hi guys ,
Kitkat is right . If driver maintan foot pressure on pedal , amount of fuel injected in comb chamber is alway the same .... Stock plug and cable is designed for less 70% comburstion . High tension cable with thick conductor with give more conductive to voltage . That mean more voltage will exist at spark plug to create big spark . contribution of high tension cable to comburstion is better than stock one .. more Than 85 percent fuel will burn ... But disadvantage appear on stock one also exist on high tension cable ... Spark still in mixture of orange and purple color ... This type of spark always create unhealthy flaming in comb chamber .. Flaming in light orange color will come out some side priduct like carbon composite and high temperature ...
Why piston head can blow hole leh ? no because high tension cable caused this damage lah .... This damage alway cause by explodetion in comb chamber due to fuel ratio vs air is out or low pressure after piston compress mixture ... Flaming is preferable in comb chamber , but not explodetion . Explodetion will cause knocking , that mean sudden hit to piston head .. Flaming will split even energy on piston head and push down piston ...
why nology hotwire is prefferable ? this cable can cause spark plug to create big spark with plasma color .. This type of spark will burn mixture in blue flaming ... products after burn are gas CO2 and hidrogen .. That y this wire expensive ... check photo album 'latest list' for clear pic on demo .... tittle nology hotwire demo pic .....
kitkat80
Posted 25 September 2004 - 02:24 PM
kitkat80
    Hot Rod
  • PipPipPipPip
  • 10,646 posts
hehehe..thanks to Emanage for the through explaination Smile ThumbUp
Emanage
Posted 25 September 2004 - 03:15 PM
Emanage
  • 4,698 posts
kitkat,
just my two cent nia .... hihi
kitkat80
Posted 25 September 2004 - 03:20 PM
kitkat80
    Hot Rod
  • PipPipPipPip
  • 10,646 posts
i think ur one is 20cents liao lah Big Smile
Emanage
Posted 25 September 2004 - 04:03 PM
Emanage
  • 4,698 posts
aduh... 20 cents pula .hihihi
kitkat80
Posted 25 September 2004 - 04:11 PM
kitkat80
    Hot Rod
  • PipPipPipPip
  • 10,646 posts
well..some opinion are worth 1 cents...some 2 cents....but urs...i think
this one got at least 20cents value...heheh...mine..most of it is null cent
ones. Big Smile
Emanage
Posted 25 September 2004 - 05:43 PM
Emanage
  • 4,698 posts
kitkat,
your one null cent ? wrong wrong ... should be 1 ringgit..
yinho
Posted 25 September 2004 - 08:50 PM
yinho
  • 1,464 posts
good explaination but why stock cable n plug is designed only for 70%
only leh?
