Engine oil drain valve
, Aug 20 2007 03:16 PM, 157 replies to this topic
Posted 25 August 2007 - 10:43 AM
911 and JJO,
is ok, take your time..none of us is hurry.. keke
you can try to go to sparepart shop to ask for the sample plug, then can try measure the "tread size" by
use spanar or whatever tools.
not measure the Hex crew size..is the "tread size", that is the one to insert into the hole.. :P
Frankie
www.myoilstore.com
Frankie
www.myoilstore.com
Posted 27 August 2007 - 04:00 PM
Waja 1.6 4G18 use F106, u need to order adapter.
Myvi, Kembara, Avanza use F103, no need adapter.
i just measure my ATF plug, it showed 17.8MM, but dont have this size, only got 18mm..dont know can
in or not..
in or not..
Posted 27 August 2007 - 05:46 PM
wira should use F106..
but i not 100% sure lah..
u go to spare part shop ask and ask them waja plug can use for wira or not..
if can use, then is F106..
but, make sure the plug hole area got enough clearance..if not, have to buy adapter..USD6
my waja need adapter..
u check this link for better understanding what i am saying..
http://www.villacort...to_drain_valve/
Frankie
www.myoilstore.com
Frankie
www.myoilstore.com
Posted 29 August 2007 - 11:47 AM
this is the reply from fumoto...
> Hi,
> i just measure the ATF Drain plug and it show
> 17.8mm-17.9mm.
> so can i use the 18mm Drain Valve?
> Frankie
Frankie,
Yes, Mitsubishi uses 14mm and 18mm on most of their crankcase drain
plugs,
so it makes sense that the gearbox plug is also 18mm. The part # is
F-104
(regular type) or F104N (Nipple type) Please see the attached
drawings.
Thanks
Norio
their email is fumotousa@msn.com, the info@fumotousa.com can't pakai one, email them few time but
not reply..
Frankie
www.myoilstore.com
> Hi,
> 17.8mm-17.9mm.
> Frankie
Frankie,
plugs,
F-104
drawings.
Thanks
Norio
not reply..
Frankie
www.myoilstore.com
Posted 01 September 2007 - 08:03 PM
gjrforce,
so is the gearbox plug same as the engine oil drain plug?
thanks^^
thanks^^
Posted 03 September 2007 - 11:00 AM
Hi Step3382,
yes, there are just doing the samething...
but normally a ATF plug will build-in a magnet on the screw..
btw, fumoto didn't sell ATF drain Valve, but if u know the correct size of the your ATF plug, i think is
do-able.
so i get the correct size Engine oil drain valve and put it for gearbox, i will put some Harddisk magnet
near the plug as well.
Frankie
www.myoilstore.com
do-able.
Frankie
www.myoilstore.com
Posted 03 September 2007 - 11:05 AM
1, gjrforce--3 ( F103 (2 unit), F104 (1 unit)
2, clausewitz- (F103, 1 unit)
3, 911--1 (but don't know the actual size to buy)
4, anubis - F-106 regular valve (1 unit)
5.JJO-F-103 (1 unit)
cool! we got 7 orders..i think we are achive the target.
i would like to make the due date as 18 sep..
let me know if got any objection.
Frankie
www.myoilstore.com.
Frankie
www.myoilstore.com.
