Wira 1.8 clutch
ijam
, Mar 28 2003 11:10 AM, 9 replies to this topic
Posted 28 March 2003 - 11:10 AM
If u guys planning to change your Wira 1.8 clutch if your current clutch start to wearing off... what type of clutch u guys going to change it, original ?? Exedy ?? others ?? With a budget between RM500 - RM1,000 of course.
Posted 28 March 2003 - 01:38 PM
Since your max budget is RM1k, go for Exedy Metal Clutch RM880 + RM120 for installation :D
Posted 31 March 2003 - 02:20 PM
IIsaw,
Any particular reason why u prefer stock Wira 1.8 clutch instead of Exedy Metal Clutch as Variablevalve mentioned ??
Posted 31 March 2003 - 03:02 PM
i think its advisable to keep the clutch system in conformance with its designed in performance.
if you run a racing clutch plate with the stock clutch cover, there might be slippage cause the OEM pressure is not great enuff.
if you use OEM performance covers and bearings, then use OEM performance clutch plates.
if you use high performance clutch plates, then use high performance covers and bearing. the system should have matching components. it is also advisable to upgrade your engine mounts if you use high pressure clutch systems.
Posted 01 April 2003 - 11:32 AM
Unless you need the power or your clutch is slipping the stock clutch is
always the best compromise.
It's quiter than the Exedy unit, u can slip the clutch which you cannot on
the Exedy and the clutch pedal is much lighter and less taxing on the foot..
Posted 01 April 2003 - 01:26 PM
Btw, does anyone here knows how much is the oem clutch plate and cover for
proton wira1.8/putra/sgti?
Can we get it from any roadside mechanic or must go back to Proton Service
ctre?
Also what about MMC clutch, anyone knows the price and part no.?
ctre?
Posted 01 April 2003 - 03:04 PM
you can buy the OEM plate/cover, made by exedy for around RM400+
it is more than adequate for fast road driving, and the occasional track
days.
days.
