Siemens SGTI Distributor & Alternator Earth Screw
gtiwtks
, Aug 21 2006 04:15 PM, 7 replies to this topic
Posted 21 August 2006 - 04:15 PM
Any Siemens SGTI owner who diy install their grounding cable? I intend to
redo the grounding point but can't seem to find the Distributor and
Alternator Earth Point. Can anyone give me some guide. Would be glad if
photo is provided.
photo is provided.
Posted 22 August 2006 - 07:52 PM
Ask Drex lor he is well verse with S-VDO groundings....
yo... I did dyno and yes the RCAI does give back some HP!!!
Have you sorter your aircon yet or your grounding causing problems isit?
Posted 23 August 2006 - 10:16 AM
Grounding also depend on SVDO and MMC?
No la, the air con not yet sorted la, lack of vitamin M.
I suspect grounding might have some problem base on the pivot grounding
instruction as my is different. As first, mine grounding does not connect
to the alternator earth point. So go through the web site and look how to
connect. Then found one :-
http://autoweb.com.m...m/allposts.asp?
forum=ap200110301&subject=Correct+grounding+point%
3F&Access=1&Status=1&page=1
and follow it except the distributor part.
Remove from the so called alternator earth point, the air cond drag is
shorter and air cond compressor will kick in mostly after 3th gear change
but the rpm drop very fast when air cond compressor kick in. Connect
back, air cond drag is longer and air cond compressor kick in on 1st gear
most of the time but the rpm drop slowly when air cond compressor kick in.
Will dry to remove it again to confirm.
Do dyno so cheap one ah? U seem to have done dyno for many times.
Posted 23 August 2006 - 12:14 PM
who says is cheap! for the sake of R&D and to prove my words to you cause
you said I "chiu sui" about the RCAI lor! because of that I always keep
my words one and make sure what I R&D works and not otherwise mah! else
you dowan to yumchar with me next time how?
hey got something keng for extractor! new design hehehehe! wait I R&D and
dyno for my car 1st then you can try!
Posted 23 August 2006 - 05:59 PM
I mana ada said the RCAI chiu sui? Is just my car got air cond problem so
hard to notice. Even without the air cond on, it still sucking cooler air
compare sucking air from the engine, right? Im pretty sure after my
nightmare solved, my car will benefit from it. I think FC quite good even
i tekan alot and stuck in traffic several time. I
How much u do dyno? If within budget, might think of do it too since
never try before. Wanna see got any improvement in actual data. So far,
the modification done is dyno by my "loh you". LOL.
When ur engine damper kit going to commercialise? Lol.
Posted 24 September 2006 - 03:47 AM
Oh.. just notice this thread.. what lar you rikeys, put me on the table
again.
gtiwtks, your grounding issue settled?
again.
Posted 25 September 2006 - 10:15 AM
Drex,
Took you so long to notice this thread ah? Rikey didn't put you on the
table la, just merely recommend only because u are prof of siemen's
proton. LOL.
No yet settled la. Both the distributor and alternator not yet grounded.
Can't seem to find the earth screw.
Do advise.
Appreciate with many thanks.
proton. LOL.
Do advise.
Posted 25 September 2006 - 12:12 PM
distributor - just ground to the block where it's mounted.
alternator - there's one nut, hidded behind the extractor, you need to
do it from below.
do it from below.
