Intermitent ABS problem
Posted 03 September 2003 - 05:00 PM
Can it be repaired?
A new one, I hear costs about $6000!
Posted 03 September 2003 - 09:51 PM
to ask the repairman to check on the abs sensor located at your
brakes first.
Posted 04 September 2003 - 10:41 AM
mystery ABS problems.
Posted 04 September 2003 - 04:27 PM
That means the sensors are fine right?
Posted 04 September 2003 - 08:37 PM
instantaneous stop?
Posted 04 September 2003 - 10:33 PM
It started after I changed my brake pads to don advantage.
Posted 05 September 2003 - 04:40 PM
abs if i were you and make sure the garage knows what they forgot to fix
back.
Posted 05 September 2003 - 04:50 PM
Only thing is I did it a long time ago, and at that time I thought it
will just go away(wishful thinking)
The Don brake pads are not very good either.
I guess I will have to take it to the workshop one way or other.
aiyooo pokai lah macam ni.
Posted 07 September 2003 - 11:14 AM
got it rectified.
Good luck.
Posted 08 September 2003 - 10:02 AM
will come on. the warning light means that ABS is not working.
and of course, if your wheels lockup under hard braking.. its definitely
not working.
