anti roll bar
Aquua
, Mar 26 2003 11:32 AM, 11 replies to this topic
Posted 26 March 2003 - 11:32 AM
yes, chrome is right..what i meant is anti roll bar instead of rear strut bar..so anybody knows where to find it...any recommended workshop?..if i put that stuff i can take korner lipat loh..
Posted 26 March 2003 - 05:13 PM
what car are you driving?
if satria, get from kedai potong set of rear lower arm with ARB. will cost around RM200+/-
Posted 26 March 2003 - 05:58 PM
Aquua,
If you're looking for ARB, I have a set of front and rear from a 1.8. I can throw in the bushes as well if you're interested. Installation can be arranged if needed.
sms me : 019-3230882
Posted 26 March 2003 - 07:38 PM
does wira 1.5 a/b comes with rear ARB? if get 3rd party one how much and where to get? anything to change/replace?
Posted 27 March 2003 - 08:51 AM
For rear antirollbar, you have a few options...
1) OEM Wira 1.6/1.8 ARB, 13mm diamater, bush linkage on top, rose joint bottom
2) Cyborg Mivec ARB, 15mm diameter, rose jointed top and bottom
3) OEM Putra pre-1998 ARB, 16mm, bush top, rose joint bottom (this I can't confirm, according to other sources)
4) Satria GTI ARB, 13mm, rose joint top and bottom
5) Whiteline ARB, 18mm?, rose joint top and bottom, or bush top, rose joint bottom
You will need the ARB, joint links, mounting bracket+bushes, and correct rear lower arm for complete installation.
Posted 27 March 2003 - 02:11 PM
am drvng wira 1.5 hehe...so can install ka?is it wira has a same base to install...but if to find at kedai potong,how to know that it was a right thing..any picture or not?
Posted 27 March 2003 - 03:40 PM
I belive that the 1.5 lower arm does not have the lubang for the ARB, need to change the lowe arm too.
Posted 27 March 2003 - 05:00 PM
Hi, friends, I have installed the 15mm OD ARB in my car. Anyway, the original lower arm need to replaced with the one come with bracket. i am very satisfy with the setting especially in high speed cornering.
Posted 27 March 2003 - 06:39 PM
Mileage only 10k when I removed it from my car. For a 1.5 you need to weld mounting joints to your lower arm. An alternative would be to change them to 1.6, 1.8 or even Evos :)
