bosch super 4 vs NGK
Posted 11 November 2008 - 08:07 PM
u know de mileage/life span for de plug NGK BPR5EIX ma...?
bosch super 4 gap is 1.1 mm or 0.8 mm....?
Is iswara/saga original plug gap is 0.8 mm ma...?
If use plug gap of 1.1mm on iswara that is 0.8 mm...is ok ma...?
Posted 12 November 2008 - 11:20 AM
do you carry NKR IRI range high performance plug ? was looking for heat
range #7 gap 0.7mm for mid tuned volvo turbo engine ...
Posted 12 November 2008 - 05:18 PM
out as fast as normal copper plugs, i.e. around 30~40k km. So, Super 4
gives better value for money in terms of longevity.
Posted 12 November 2008 - 10:57 PM
About Super 4, the gaps are set at 4 different mm, that's why it is 4
legged and can't be regapped or side gapped.
Posted 13 November 2008 - 01:04 AM
ignition key to start..de car will start up in 1 second in 1st crank.. But
sometime it needed 3-4 second to start up on de 1st crank.. And sometime
too it needed 2nd crank to start de car by pressing de car petrol pedal...
I thought by changing to a better spark plug can solve de problem...but
still de same wor... Any idea how to have a fast start up on de 1st
crank..? Some suggested to get better & thicker plug cable for de
ignition...is it true..?
Posted 13 November 2008 - 09:17 AM
BPR6EGP are gapped at 0.8mm.
I'm regular user of G power (BPR6EGP), found that the performance is
fine. The drawbacks are, bad cold idling and short lifespan. Bosch can
generally last longer but performance is just above average.
Chris, most of the LMST are like that, you need to press on the
accelerator a bit during cranking. Anyway, we just cannot expect the same
quality of crank start like the fuel injection model.
Posted 13 November 2008 - 01:46 PM
So, do u mean that g power is better than super 4 in terms of performance?
But super 4 will last longer? For wira 1.5 injection, do I need to choose
1.1mm gap got g power? Need u all's opinion which is better for these 2
plugs. TQ
Posted 14 November 2008 - 01:28 AM
you either choose Bosch or NGK or even Denso, Champion and etc.
Generally, 1.5 injection (step 2, Siemen VDO) should be fixed with 1.1mm
gapped plug. The part no is BP5ES-11, hence if you want a platinum with
built in resistor, and 1.1mm gap, you need to go for smaller spanner hex
(16), BPR5EGP. When the engine is warmed up, I would say the G power will
perform a bit better than Bosch, be it YYtrium plus or Super 4. But Bosch
has a flagship model called Iridium Platinum Fusion, I think it should
perform better than G power and should at par with other Iridium models.
Posted 24 November 2008 - 03:22 PM
NGK Iridium can last quite well..my ex set last me 80k km...i also forget about it untill i read my
record book.
spark plug is also very depend your engine condition and driving habbit, generally it last quite well for
NGK brand.
Bosch super 4 i not sure.
Isawa/saga from 1st gen to last gen is using BPR5EIX with 0.8mm gaping.
If using 1.1mm, some maybe feel mis-fire and FC will be affected, but some just feel normal je..
Generally, using 0.8mm (if your engine need it), u will feel better FC/power if u using back 0.8mm.
my friend gain extra 100km per tank.
Posted 26 December 2008 - 12:18 AM
YSW,
I just brought NGK platinum, the model is BPR5EGP from spare part shop. Is this model suitable for wira 1.5 injection auto?
Please advice.
Thanks.
