Dear All,
Anyone hear of this Bioion fuel cracker? It claims to improve FC and power.
Bioion fuel cracker
Yet another performance enhancer has entered the market. Clipped onto a
fuel line, Bioion breaks up fuel molecules with a magnetic device.
Yet another device said to be able to boost horsepower and save fuel has
been made available. Called Bioion, it is a fuel cracker that uses
magnetics to break up fuel molecules inside the fuel line.
In an ordinary situation, the molecules of fuel inside a fuel line are
bunched together and when the fuel-air mixture gets fired, the combustion
is often inefficient due to the clumping together of the molecules. Bioion
treats the fuel clumps by charging them with a single polarity, which
causes the molecules to repel each other and hence, break up the clumps.
Upon dispersion, the fuel-air mixture ignites readily and combustion is
more complete. The result, says Bioion, is better power, reduced fuel
consumption and even help in the removal of carbon deposits.
cheers,
innocent
Bioion fuel cracker
innocent
, Dec 30 2004 04:57 PM, 4 replies to this topic
Posted 30 December 2004 - 07:03 PM
do you need to cut the fuel line to install the Bioion? I think it is
risky to unplug or cut the fuel line because if you or the installer
mucks up the installation and didn't tighten back the fuel line (meaning
no leaks), the engine may catch fire. Petrol is ultra flammable and the
fumes itself can ignite and cause a fire. Don't play play! I think buying
stuff like the RMK Magnefuel is far safe because you just clip it over
the fuel line and requires no cutting or modification to the fuel line.
Posted 31 December 2004 - 08:52 AM
thanks buddyclub.
I think the Bioion fuel craker does not need to cut the fuel line. It is
also clip over the fuel line. May I know where can I fine this RMK
Magnefuel from and roughly how much does it cost?
cheers
innocent
cheers
innocent
Posted 31 December 2004 - 05:46 PM
hey innocent,
The RMK MAgnefuel is available thru Automotive Synergy. They have adverts
regularly in a few local car mags. I think their number is 03-71183633. I
saw a promo they are having now: RM99 per box but if you buy 2 box, u get
the 3rd one free. Meaning 1 fuel saver and 2 fuel boosters for the price
of RM198. Average price of RM66. Reasonable price. The fuel booster
magnefuel helps improve throttle response.
