Spark Plugs
Posted 22 December 2005 - 12:54 PM
around...seems like the shops don't carry them. so, are there any other
suitable brands/models besides the manual recommended NGKs? thanks for the
help
Posted 22 December 2005 - 02:41 PM
normlly have stock. avoid golden lodge as it get hotter faster than NGK.
further more, it doesn't last long compared to NGK - 50k km vs 100k km.
Posted 22 December 2005 - 05:55 PM
get someone to do the running bit.....thanks for the tip.
Posted 25 December 2005 - 02:31 PM
NGK PFR6B - yes can go for 100km,
but u can change it (Golden Lodge)the times u replace timming belt at 45K
or 50K km, its not difficult to replace it, no like V6 engine
Posted 26 December 2005 - 12:43 AM
boxer 16v - NGK PFR6B - replace every 100k km
boxer 8v - Lodge 25HL - replace every 40k km
don't get the wrong one for your boxers.
Posted 26 December 2005 - 01:23 PM
and as the manual says, NGK PFR6B. golden lodge is for the 8v boxer. so,
do i still go for ngk or golden lodge? i was told that if i know the heat
range/electrode for the ngk pfr6b, then i can use other makes with
similiar properties! prob is i don't know what are the compatible
makes/models!
Posted 26 December 2005 - 05:28 PM
0.7mm. If you can find out the heat range which is similar to PFR6B,
perhaps you can give it a try. Hey, some people even use Iridium for their
boxers.
I’ve been using PFR6B since day one (don’t have the courage to mess with
the engine) and have so far covered 225k km, without major problem.
Posted 27 December 2005 - 01:09 PM
RM12/pc. Replaced every 40K. Seems ok. Dont know what to say lah. I just
use the parts that recommended by all the boxer`s owner. Every 40K u have
to change your timing belt so why not u change spark plugs as well. Go
for the golden lodge.
Posted 27 December 2005 - 01:17 PM
what? Is it the spare part shop? Can u give me their phone number or
location? thanx.
Posted 27 December 2005 - 10:11 PM
boxer, according to the manual. is your boxer the 1.6 or 1.7? btw, found
out that the ngk iridium bkr6e1x (6418) is compatible to the ngk pfr6b.
perhaps will consider the irridium!
