Peugeot 206 Fuel Consumption (fc) Database
#101
Posted 02 November 2010 - 07:33 PM
My sweet peugeot 206 1.6 16v
Mod list : k & n typhoon air filter , 4-2-1 mandrel bent custom extractor , full piping s-flow brand topcat 1.6", denso iridium spark plugs, Unichip Q tuned by RS Impressive, 16" OZ rims
Max BHP & torque : 127 bhp @ 6,00rpm , 173 nm @ 4,000rpm (tuned for torque)
#102
Posted 25 November 2010 - 03:17 PM
Reason was that the 206 has had a massive 'organs transplant' and thus the more-than-adequate 1.6L engine has since been rested (in peace).
The new power plant is being use without too much concern regarding it FC and thus FC wasn't monitored as before. But i do drive sensibly for most of the time.
I intent to monitor it and contribute the data in the future, perhaps by the end of december or early next year.
Nevertheless, a simple on board FC information (from the multi function display) showed that for the last 5,000km, my average FC is at 8.1L/100km @ ~12.34km/L @ 617km for a full tank of petrol.
Which is not bad at all actually, as this is not far off from the old engine FC figure (based from the multi function display too) which averaging @ 7.8L/100, so just around 4.5% increase.
Still using BHP RON97, no plan to change.
#103
Posted 17 December 2010 - 09:58 AM
The trigger-happy 'pedal-to-the-metal-as-and -when -i-wanted-it' period is over.
Now will be driving more sensibly, as much as i could lah.
But it will be a bit different as i've decided to switch to BHP RON95 petrol (was using BHP RON97 for quite sometime before).
Still too early to share the result, but so far, after around 500km of use (with RON95) the average FC is around 7.9L/100km.
Here a simple summary of my FC for RON97.
Distance Travelled: 5654km
Average speed: 45km/h
Average FC (format 1): 8.1L/100km
Average FC (format 2): 12.34km/L
Average FC (format3) : 5.876km/Ringgit (Petrol @ RM2.10/L)
Petrol Utilised: A Lot!
Full tank mileage: 617.28km
#104
Posted 23 December 2010 - 01:39 AM
leroy.
#105
Posted 23 December 2010 - 05:54 PM
it's manual calculation for bestari owner...... only the 1.6 and above have this so call button
#106
Posted 28 December 2010 - 05:00 PM
Okay.. let me try to explain it...
1. Distance Travelled: 5654km
This figure you can get from the MFD (multi function display) / Car Telemetry (for CBU unit only). Had to set-up first. If you don't have it, you have to manually recorded it. Use the mileage or the journey counter from the speedometer. Or calculate the difference between two full fill-up. That's your distance travelled.
2. Average speed: 45km/h
This is only available as a function from the MFD.
Bestari dont have it, I'm afraid.
3. Average FC (format 1): 8.1L/100km
i. Available as a function from the MFD. again, Bestari don't have it.
Note that figure from the MFD is always lower (i.e. better) than manually calculated figure. Suggest to display both.
ii. Can be manually calculated. You need distance travelled info (x), and how many liters of petrol used within the distance travelled (y). divide the distance travelled figure (x) with 100 and you get (z). then divide (y) with (z) and you get (w).
Then you should get it as: (w)L/100km (manual calculation).
4. Average FC (format 2): 12.34km/L
Manually calculated. You need distance travelled info (x), and how many liters of petrol used within the distance travelled (y). divide the distance travelled figure (x) with liters of petrol used (y) and you get (z). then divide (y) with (z) and you get (w).
Then you should get it as: (z)km/L (manual calculation).
5. Average FC (format3) : 5.876km/Ringgit (Petrol @ RM2.10/L)
Manually calculated. You need distance travelled info (x), and price of how many liters of petrol used within the distance travelled (y). divide the distance travelled figure (x) with the price (y) and you'll get (z).
Then you should get it as: (z)km/Ringgit (Petrol @ RMw.ww) (manual calculation). (w.ww depends on price of petrol that you used)
6. Petrol Utilised: A Lot!
This is a bit tricky, but very essential part of the whole scheme.
To establish this, first you need to create 'baseline'.
Best if you fill-up the tank in full (stop after the pump mechanism kicked forthe first time).
Then when you need to fill-up again, fill-it up full again (and also stop after the pump mechanism kicked forthe first time). By doing this, you will get create some sort of level of confidence that the tank are fill-up almost similarly everytime.
Between this two full tank fill-up, you wil get:
i. distance travelled
ii. liters of petrol used within the distance travelled
iii. cost of petrol used within the distance travelled
Now you are equipped with the base data to calculate your fuel consumption.
7. Full tank mileage: 617.28km
Peugeot 206 fuel tank is estimated to be able to hold 50 liters of fuel.
Therefore, take the average FC (format 2) value (x.xxkm/L) and multiply it with 50.
Example if the average FC (format 2): 12.34km/L (Note: This was rounded up to 2 decimal figure. Actual value = 12.3456);
12.3456 times 50 = 617.28
Therefore, full tank mileage: 617.28km (manual calculation).
Hope the above explanation helps.
Happy trying it out. It does re-fresh the arithmetic side of the brain!
#107
Posted 03 January 2011 - 10:32 AM
Contributor : Intermilan
Reading Number : Intermilan10
Vehicle : Peugeot 206
Engine code : EW10J4
Engine type : 2.0L 16V
Engine modification : Light
Transmission type : Manual
Fuel brand : BHP
Fuel type : Petrol, Unleaded, RON95
Reading Type : Car Telemetry & Manual Calculation)
Distance Travelled : 1967 km
Average Speed : 50km/h (Car Telemetry)
Average FC (format1a) : 8.268L/100km (manual calculation)
Average FC (format1b) : 7.7L/100km (Car Telemetry). Figure from car telemetry is always lower.
Average FC (format2) : 12.094 km/L (manual calculation)
Average FC (format3a) : 6.365 km/Ringgit (Petrol @ RM1.90/L) (manual calculation)
Average FC (format3b) : -.--- km/Ringgit (Petrol @ RM-.--/L) (manual calculation)
Average FC (format 4) : 0.157 sen/km (Petrol @ RM1.90/L) (manual calculation) New formula
Petrol Utilised (L) : 162.64 liter
Traffic Conditions : Combined / Mix-Urban
Full Tank Mileage : 604.70 km
#108
Posted 26 January 2011 - 02:33 PM
Reading Number : Intermilan11
Fuel brand : BHP
Distance Travelled : 1362 km
Average Speed : 45km/h (Car Telemetry)
Average FC (format1a) : 8.322L/100km (manual calculation)
Average FC (format2) : 12.016 km/L (manual calculation)
Average FC (format3a) : 6.325 km/Ringgit (Petrol @ RM1.90/L) (manual calculation)
Average FC (format 4) : 0.1581 sen/km (Petrol @ RM1.90/L) (manual calculation) New formula
Petrol Utilised (L) : 113.35 liter
Full Tank Mileage : 600.870 km
Comments:
Results are very similar with previous 'official' reading, just this is a smaller sample (distance travelled are less by 30%).
It begin to look like 12km/L is the FC that i'm going to get from the 'new' engine.
Looking pretty good to me as the 'old' 1.6L 16V engine returned similar values for most of the time.
#109
Posted 27 January 2011 - 10:08 AM
Fuel brand : BHP
Comments:
very impresive inter. good fc . lg2 manual
#110
Posted 28 January 2011 - 12:08 AM
was quite surprise myself. was expecting around 10% worse.
well.. i think the FC will get worse once i've re-mapped the ECU.
right now, all stock.. boleh la.. default mapping memang bias towards fuel economy..
we'll see how it goes.. until then, will continue to monitor and share my FC.
