Wiring and Rattling sound underneath
shammur
, May 12 2003 01:00 PM, 14 replies to this topic
Posted 12 May 2003 - 01:00 PM
wel guys, i got my zx few weeks ago.
everything was fine as i wants it. great performace n stability.
but i got few prob here to 'tune' it to a better zx.
1-wiring
where can i find a fair charging wiring mechanic
i got this prob abour my central locking, i knew citroen has auto delay
central locking, the used car dealer dont borther to fix it. or i just
fixed those Brothers kind of central locking system?
2-rattling sound
i m not sure if its coming from exzos pipe, which is not locked properly.
but the sound came from there, in front, below front seats.
3-aircond
when i press the aircond switch on, 1 second its on, 1 sec off again, then
on then off..like beeping on n off?...might to do with wiring? y
4-faulty air filter hose (bocor da!)
where can i find a replacement
others so far is great, better then satria 1.6xli i ve had b4
1-wiring
2-rattling sound
3-aircond
Posted 12 May 2003 - 07:27 PM
welcome ,
as for your questions I am sure the sifus will come to the rescue in a
short while anyways I reccomend you do an advance search on the issues
you will be able to access the more info from previous threads
Posted 13 May 2003 - 03:11 AM
Item #3
if affect only the aircond not the blower, then most probably is that
switch problem, it's common fault, just dimantle the switch into pieces and
clean it with very fine sandpaper and contact cleaner.
Posted 13 May 2003 - 09:38 AM
Shammur,
For item 3, you can bring to Ming Wah Auto, he is a air-cond specialist
located off Jln TAR. Its behind the Honda showroom, which is after Pizza
Hut, if you're heading towards KL.
Search for the tread "Radiator Fan" which was posted by me.
Good luck.
Good luck.
Posted 13 May 2003 - 02:52 PM
thx derek..
i will check tht place out tmrw..dier cuti ka?..i mean wesak day..?
and u think he can take a look at my rattling sounds too?
Posted 13 May 2003 - 03:03 PM
ok..quit adventurous though...i mean dismantle it myself..
coz i m not sure how..can u allobarate..
thx
thx
Posted 14 May 2003 - 01:51 PM
went there.
he said the switch is faulty..need to change it..for RM120 a piece
standard price?
or ph auto cheaper?
standard price?
or ph auto cheaper?
Posted 16 May 2003 - 11:02 AM
top mounting?
hmm..how come i hav to check at the top...
when the sounds r coming from the bottom?
do u think it is the 2 rubber tht holds the exzos pipe?
the aircond switch?...RM120 at ming wah..reasonable ka?
Posted 16 May 2003 - 11:06 AM
did clean it with the sand paper..
but stil blinking n not proper..i mean press down = on / press bac up = off
i hav to 'finger' it few times to get it on...
