zairi .. you sure the rm75 per 3pcs pack is original .. i dun think so !
Original lower arm bush (big) cost about Rm100 to Rm120 per piece and it
last years and years. Normally nowadays many opt for sasic which is about
Rm55 per piece (big lower arm bush). 1 set for 3pcs lower arm bush (per
side) if it's sasic it'll cost you maybe Rm120 or slightly more or less.
If you can get original 3pcs pack for Rm75 ... i'm gonna go and kow-tow
you cos that's dirt CHEAP ! With Euros not being stable ... i really
doubt the price la.
perhaps if you could enlighten us the shop location so that we can serbu
and check on the unit.
CR
bushes
rfbu
, May 13 2003 01:13 PM, 13 replies to this topic
Posted 09 June 2004 - 09:48 AM
BlackZX,
the worn bush that'll cause power steering fluid leaks would be the
steering damper(absorber) bush. There are 2 pcs of them only for the
damper, located adjacent to the steering rack (middle of car). Have to put
the car on a ramp/hoist to assess properly.
Lower arms are on the LH and RH side front wheels. So, 3 pcs for LH and 3
pcs for RH.
Guys, what is this vertical rod that can be seen inside the front mudguard?
Not what we normally see on Japanese (and Malaysian) cars I suppose? What
does it do?
Cheers!
pcs for RH.
does it do?
Cheers!
Posted 10 June 2004 - 04:20 PM
thanks BV,
what's the purpose of the lower arm bushes then ? purely comfort reasons
or mechanical running of the vehicle ?
Posted 11 June 2004 - 12:40 PM
BV,
Is it the link rod? If it is, someone told me its for cornering...
Satablised our french babes...
