berlingo
adi79
Posted 11 October 2008 - 01:07 AM
adi79
    3rd Gear
  • 3 posts
Hi to all sifus,
I'm kinda new here...
I need your opinion and suggestion, which is the best car to choose from;
1-Citroen Berlingo
2-Peugeot Partner
3-Renault Kangoo
4-Toyota Avanza
in terms of luggage space, stability, fuel consumption,pick-up (naik
bukit in full load mode) and comfortness?...other than that, don't really
care (design, make-up)...
Any comment, opinion and suggestions from sifus are much much welcomed :-)
Thanks in advance for you generous help. :-) :-) :-)
#132
Benson
Posted 11 October 2008 - 01:22 AM
Benson
  • 2,067 posts
Citroen Berlingo & Peugeot Partner just a difference Emblem only, I'm still
looking for that lion logo to replace with my HILL's LogoBig Smile
so, basically is compare wither you want japanese or continental, if you
want want high resale value, low maintenance cost than of cost Japanese
made, but if you insist of handing, space, personal unique taste +
character, and the superb shape outlook, then you can either consider the
used Berlingo or New Kangoo, and from what I know, Kangoo is more
troublesome and problem than Berlingo, and if you really want at to
consider a used Berlingo at good condition and best price. let me know, I
got one to sellSmile
#133
spmoi
Posted 13 October 2008 - 10:39 AM
spmoi
  • 220 posts
hi ad79,
As Benson said, Citroen Berlingo and Peugeot Partner are the same car. Just
different logo.
If you want a simple, easy to find a workshop and (low maintenance cost),
then go for avanza. I bracket out the "low maintenance cost", because it is
highly depend which part of your car need to maintain. If you talk about
normal engine components, brake pad and accessories. Yes, avanza is lower
cost. But when you talk about air-con maintenance. Then you must check with
the advanza owner who service their aircon before at Toyota Service Center.
Steering oil flushing also quite expensive for avanza.
Meanwhile for Berlingo and Partner, you get a 15,000KM service interval
(must use FULLY Synthetic Engine Oil). Although, the spare part price a bit
on high side. But because of longer service interval you can save up more
on labor charges and you time to wait at service center. So, normal
maintenance cost is also same with avanza. But, when you service you
aircon. Berlingo and Partner aircon is built in with a air-con filter. So,
you are almost no need to service you air-con coil with 10yrs. Until your
air-con coil is too dirty or leaking gas, only need to service it. But,
before owning Citroen and Peugeot car, please do some home work. Find out
where is the good workshop. Where to get the spare part from. Then you
should no problem to own the Citroen and Peugeot car.
Kangoo is almost similar with Berlingo and Partner. The Kangoo seat is more
comfort than berlingo and partner. Just a bit different on outlook, and the
service interval is 10,000KM. But someone drag it to 15,000KM.
Handling and comfort wise... no need to say..... hardly to beat conti car.
#134
adi79
Posted 14 October 2008 - 10:03 AM
adi79
    3rd Gear
  • 3 posts
Hi Benson and Spmoi,
Thank you very much for the good info Cool
So, after this need to do alot of homework and 'kerja keras' before
consider to buy peugeot or berlingo or kangoo.
btw, thanks again.
#135
Benson
Posted 14 October 2008 - 01:09 PM
Benson
  • 2,067 posts
please take note that the new kangoo is CKD while the used berlingo is CBU.
I got one Piece to let go, you can let me know if you interested
#136
berlingo2
Posted 28 October 2008 - 03:04 PM
berlingo2
  • 65 posts
hi all bro,
pls help, my berlingo's driveshaft cover/rubber (drive side) crack. Asked
spare parts shop for price, they mentioned the access hole there got 2
type, round or triangle, which one for my berly2? anyone experience on
this? how much will charge for replace this? any workshop to recommend?
thanks.
david/
#137
Benson
Posted 28 October 2008 - 05:50 PM
Benson
  • 2,067 posts
Call Tony lo for me information, he also drive berlingo 0126160660
#138
sakvertor
Posted 29 October 2008 - 10:29 AM
sakvertor
  • 34 posts
My opinion
1-Citroen Berlingo
2-Peugeot Partner
- same build and spec. but if not mistaken if you can get peugeot partner,
you will get your seat cover made by Quicksilver.
3-Renault Kangoo
- no where near berlingo and partner but good rival and maybe easier to
outsource parts.
4-Toyota Avanza
- if you talking about 1.5 avanza, it's better than berlingo and partner
accept at cornering and space.
luggage space,
- berlingo, partner
stability,
- berlingo, partner
fuel consumption,
- avanza
pick-up (naik bukit in full load mode)
- avanza
and comfortness?
- avanza (better NVH than others)
- up to you, I like berly2
I like to add technology used in the berlingo2
which most of the function control by your speed (speedometer)
- power steering will heavier when you speeding and cornering
- engine timing also control by speedometer
- fuel consumption also control by speedometer
- windscreen wiper speed also control by speedometer
- rear windscreen wiper will auto when you reverse your berly (if you on
front windscreen wiper)
hope this will help you to decide
#139
lostkiller
Posted 03 November 2008 - 08:17 AM
lostkiller
  • 9 posts
hello all guys,
i`m also the Berlingo 1 owner,
i buy the 2nd hand car from Last year,
i`m very Luv my car and feel it nice,stable,comfort,
but in my record....every time full tank my berlingo just can reach about
450 km /full tank.......
normally it can reach 420km only !!!
y ur car can reach about 600 km ???
any problem for my car ? why my car drink more oil > <~
please let me know how to check it or adjust ?
thx ^^
(i live at JB, Gold color berly)
#140
spmoi
Posted 03 November 2008 - 09:00 AM
spmoi
  • 220 posts
hi lostkiller,
450km is not bad. It is mainly depend on the traffic condition. If i travel
from Penang->Ipoh->Penang, I can easily get 600KM per tank. Because most of
the time my car is cruising on highway.
Firstly, check you engine oil. Make sure you are using the correct grade of
engine oil. Berlingo should go for Xw40. Lot of authorised workshops, make
a mistake by putting in xw50 engine oil into berlingo. You will feel big
different on engine power when you using wrong grade of engine oil.
Next check your air filter and spark plugs. Please do reset your ECU after
changing the air filter and spark plugs. The the ECU re-learn your engine
timing.
Gear oil, Berlingo is using grade 70~80 gear oil. But hardly get from market.
Also, check your air-con. Make sure the air-con dryer (gas filter) is in
good condition. Blocked dryer will cause engine power lost also.
