battery and jumper cable issue
#21
Posted 12 December 2006 - 09:45 PM
Always follow the manual. The sequence in my manual is as follows:
1) +ve dead battery to +ve good battery
2) -ve good battery to engine block of car with dead battery.
3) Start engine of car with good battery
4) Wait about a minute and attempt starting engine with the dead battery
5) If engine is successfully jump-started, let it idle for about 5 mins
6) Remove cables in reverse order
Some suggest revving the good-battery engine and keeping it at 2,000 RPM
after the other engine has been jump-started, kinda like to pump
more `juice` into the bad battery. Also, revving the engine that has just
been jump-started is commonly done.
Posted 12 December 2006 - 10:09 PM
showed up with jumpers and they connected the cables, WRONGLY, making the
common mistake of completing the circuit, i.e. connecting –ve to –ve.
Even the “helpers” – some guys who were attempting to help her – didn’t
know. I then went up to her and explained to her the correct jumper-cable
connecting sequence and method. I then removed the –ve clamp from the –ve
terminal of the dead battery and clamped it on the engine block.
Everyone looked puzzled and a little stunned. After I went back to my
seat (mamak stall), I saw her talking to her friend. She then undid what
I did and reconnected the –ve clamp to the –ve terminal of her car’s
battery.
And this is after I told her doing that could damage the alternator and
fuses. Well, I tried.
Posted 13 December 2006 - 08:34 AM
positive first then - negative, when take off disconnect -negative first
then +positive ????
Posted 13 December 2006 - 02:03 PM
connecting, -+ for disconnecting, just like what Sinque mentioned.
Posted 04 January 2013 - 02:15 PM
Posted 06 January 2013 - 03:40 PM
Why you need to jump start so many times. Most of the time I use the jumper to help friend car start......
Posted 09 January 2013 - 12:54 PM
then +positive ????
woah, never connect to - negative terminal of battery, always use engine block or earth body connection well away from battery!
Posted 10 January 2013 - 05:01 PM
Posted 05 February 2013 - 06:25 PM
13 months, was surprised as previous other brands can last at least 2 yrs.
went to check alternator,all ok. mech told me my old batt might hv less
plates inside, sort of imitation one. was shocked to find out the weight
differnce compare to the new one. is this true? mean i got cheated last
year? my old one was changed by outside 'don't know who' mech, who came to
'rescue' when my battery mati at parking space.
as for jumper cable case, i bought a 200amp cable, personally never use
before, but i lent to a passerby when his car batt mati, he returned the
cable, very hot. after that, i keep till this case of my car batt mati,
then find out can't jump start already. is there a fuse of something
similar or 200amp is too low? just bought a new one 400amp, is it enough?
thanks in advance for any input.
A hand-portable battery, equipped with attached cables and charger, can be used similarly to another vehicle's battery.
Portable boosters may automatically sense the battery's polarity prior to sending power to the vehicle, eliminating the damage that can result from reversing the connection...
