how to clean the engine?
mjfans98
Posted 20 July 2007 - 09:10 AM
mjfans98
  • 9 posts
recently i've read a book in POPULAR bookstore, about "everything you
should know about the basic maintenance of a car". i saw a page
mentioning about how to clean the engine of the car. it says that i
should cover the carburator with plastic bag. is there any other parts
that i should cover before spraying the engine with water in order to
clean it? or should i get "engine degreaser"? and where can i get cheap
and good quality and reliable engine degreaser?
wazzup
Posted 20 July 2007 - 09:49 AM
wazzup
  • 1,095 posts
frens, this site helps.
mjfans98
Posted 20 July 2007 - 02:51 PM
mjfans98
  • 9 posts
very informative website. thanks. can't wait to clean my engine now!! xDDD
but i wonder which parts should be covered and protected before i start
using the degreaser? hope someone could tell me. thanks. xDDDDD
perhaps i'll use the aluminium foil, and the parts that i know that
requires coverings is:
1. battery (maybe i remove it - negative terminal 1st then positive
terminal)
2. water reservoir for radiator (perhaps i try to remove this too)
3. spark plugs area (i'll cover it with aluminium foils.)
4. fuse compartments (located at the bottom left, behind the battery)
5. any other parts that u guys could tell me.
thanks.
Jerardo
Posted 20 July 2007 - 04:26 PM
Jerardo
  • 21 posts
Foil is expensive and so is the degreaser. you're planning to diy it
maybe reason being is to save cost. Maybe by sending to the car wash
people, it will turn out to be the same cost. To save cost, you can use
plastic bags. Recycling is one good way...
comanche91
Posted 27 March 2014 - 11:52 AM
comanche91
    Driver
  • 43 posts
One of the most easiest engine to be cleaned & taken care is Proton Persona Campro.
If you make a habit of buying things you do not need, you will soon be selling things you do - Filipino Proverb
nadablue
Posted 03 September 2014 - 07:11 PM
nadablue
  • 8 posts
You may get engine degreaser from the whole seller of automobile tool shop. even if you purchase more then one they provide some offers with this.
nancylong
Posted 25 September 2014 - 01:57 AM
nancylong
    Driver
  • 49 posts
  • Gender:Female
The two easiest ways of removing rust from your car engine is either by sandblasting or by using a high pressure washer. You can also do it by directly spraying the affected area with natural auto rust remover.
automotive repair services
Posted 25 September 2014 - 07:49 AM
  • 71,470 posts
QUOTE (nancylong @ Sep 25 2014, 01:57 AM) <{POST_SNAPBACK}>
V406198
Posted 25 September 2014 - 04:19 PM
V406198
  • 2,151 posts
spray direct to engine bay with dust remover ? sure your rubber/plastic materials parts will be remove together.... smile_blackeye.gif
nancylong
Posted 08 August 2015 - 01:43 AM
nancylong
    Driver
  • 49 posts
  • Gender:Female
Thank you for your suggestion I will look up to it and surely share with my friends who are in car repair and maintenance field so that
they can can also implement it in there task and deliver better product maintenance report.
