aircond servicing
shinrei
Posted 31 March 2008 - 08:37 AM
shinrei
    3rd Gear
  • 3 posts
what do they(mechanic) usually do when servicing the aircond?? just add in
gas? which aircond serviceshop is highly recommended?thankx..
alantribe
Posted 31 March 2008 - 10:19 AM
alantribe
  • 273 posts
At every 30k km, it is recommended to do a/c servicing. What usually
needs to be done (depending on car model), the receiver drier needs to be
changed and a chemical cleaning of the evaporator coil. If your car has a
cabin air filter, it is best to check or replace if needed.
BTW, what car is yours?
shinrei
Posted 31 March 2008 - 03:25 PM
shinrei
    3rd Gear
  • 3 posts
im driving a honda civic eg8. oic... how much does it cost usually?
Autoguy123
Posted 31 March 2008 - 04:49 PM
Autoguy123
U can try KH KIM LEE at Lembah maju Pandah Indah.
Step3382
Posted 31 March 2008 - 07:21 PM
Step3382
  • 285 posts
Autoguy123,
can u provide the details of KH KIM LEE?
like the actual location, ph no., pricing and how is their service?
Thanks. appreciated.
adam9
Posted 01 April 2008 - 05:46 AM
adam9
    4th Gear
  • 4 posts
Hi. if you do not use your airconditiner every now and than the seals
will dry out and the gas will leak. Your airconditioner will not need any
maintenance at all except a regass every 3 years. If you use Auto LPG
(50% propabe and 50% butane) you can double the time between regasses and
it is much cheaper. And it works better.
Autoguy123
Posted 01 April 2008 - 11:23 AM
Autoguy123
KH KIM LEE AUTO ENTERPRISE Actual location at TMN LEMBAH MAJU. In between
Pandah Indah And Taman muda Ampang. Pricing Depand on What part
Deffective, For me Is ok.More info u can call Ah Keong 03-42979899.
they also specialist in repair gear box.
Posted 01 April 2008 - 05:31 PM
  • 71,260 posts
>>>Your airconditioner will not need any maintenance at all except a regass
every 3 years. If you use Auto LPG (50% propane and 50% butane)<<<
huh... air conditioner using propane & butane?
rdgs,
ring
Posted 04 April 2008 - 02:27 PM
ring
  • 1,628 posts
air-con of course need regular maintenance. the compressor is a very
important part that need oiling. the air-con valve is also impact its
performance & I usually change it after X2 service or every 50,000km.
frequent cleaning is also suggested on air-con coil for those who drive
in dusty area.
Don't be penny wise pound folish!
mych
Posted 14 April 2008 - 12:06 AM
mych
  • 7,789 posts
check incabin air cond filter if dirty
