Hi.. this will be my first car. Just want to know your opinion which car should i buy? Used Myvi or used Preve? Thanks!
Myvi 2Nd Hand Or Preve 2Nd Hand?
Posted 22 March 2019 - 07:37 AM
Well, it depends on what you want because you are not comparing apple to apple as the Preve is larger, bigger capacity, 4 door saloon against a sub compact hatchback. If you are single and need the car for work, probably the myvi will be better. Many in the market, therefore a lot of parts, maintenance lower, etc. In you need space and a bigger car then go for Preve...
Posted 22 March 2019 - 09:27 AM
i go to work naik kapcai only. my heart want preve but nearly all my friends said to me dont buy preve la later sakit kepala mau repair buy myvi better. and do preve executive spec from 2015 upwards got any major problem?
Posted 23 March 2019 - 11:17 AM
Means you only use once in a while. Well, Preve will be more comfortable, but then most costly also. Since you don't use much, depreciation is another factor.
I have a friend having one unit but not sure which model, so far not much complaint.
