P0087 Fuel Rail/system Pressure - Too Low
P0087 diesel
singa3008
Posted 25 February 2019 - 12:14 AM
singa3008
    4th Gear
  • 4 posts
Hi, out of the blues getting fault code P0087 Fuel Rail/System Pressure - Too Low on my 3008 diesel with 95k mileage. After 1 day the code will disappear by itself. After getting it twice, it seems to happen during hard accelerate (not flooring). Everything else looks fine & no power loss at all. Could it be fuel pump issue? Anyone has encountered it before? AF appointment takes awhile to set up. Appreciate if anyone can share what their previous issue was & how serious it was. Thanks.
Mr. Engineer
Posted 25 February 2019 - 07:57 AM
Mr. Engineer
    Karl Benz
  • 76,523 posts
It could be the Fuel Pump or check that the fuel filter is not clogged.
singa3008
Posted 25 February 2019 - 02:58 PM
singa3008
    4th Gear
  • 4 posts
Thanks. Fuel filter is where to check?
Mr. Engineer
Posted 26 February 2019 - 08:00 AM
Mr. Engineer
    Karl Benz
  • 76,523 posts
Seriously, I am not sure as I would leave it to the Authorised Workshops to do a full diagnostics as they do have the tools.
As long as your car has the 5-year or 7-year warranty, it is best to go back to Peugeot.
Posted 26 February 2019 - 10:37 AM
  • 70,306 posts
If after 95k km have not change fuel filter before, should be quite dirty already. Usually the filters are in the engine compartment but then Different car brands fit their filters at different places. Just get a PUG authorized workshop to have a look if your regular mechanic cannot do it.....
singa3008
Posted 26 February 2019 - 02:04 PM
singa3008
    4th Gear
  • 4 posts
Ok thanks guys. I'll check it out during my next service coming up soon. Hopefully not the HPFP.
Mr. Engineer
Posted 27 February 2019 - 08:31 AM
Mr. Engineer
    Karl Benz
  • 76,523 posts
If you have not done it yet, the HPFP is a recall item.
Do ask at the Service Centre about your recalls if you have (must be done before June) any, plus eligibility for the 7 year warranty.
singa3008
Posted 02 March 2019 - 06:08 PM
singa3008
    4th Gear
  • 4 posts
Thank you sir, I've called & checked unfortunately no such thing for my car.
Mr. Engineer
Posted 04 March 2019 - 08:48 AM
Mr. Engineer
    Karl Benz
  • 76,523 posts
Aw, damn.
The HPFP will cost a lot unless your car is eligible for 7 year warranty, which might cover it.
Posted 05 March 2019 - 08:24 AM
  • 70,306 posts
The warranty not for all models?
