All sifus,
I am currently driving my dad's 1.5 wira gli to school everyday. Since last year I notice that the tachometer shoot up to 3.8k to 4k rpm once started. But the tachometer sometimes is functional as normal after driven on rough roads. Later on the speedometer not functioning at all. Then it's the temperature gauge which always keep the pointer at C. What step should I do to make it function?
Besides the ignition of the car has a lil problem which the clock radio and room light won't work after the ignition. I need to left turn the ignition back a bit to make the system work... What is the problem behind it?
I am thank for your helps
Proton Wira Tachometer Speedometer And Temp Gauge Not Functioning And With No Backlight
Rxforme
, Jan 06 2019 07:24 PM, 1 reply to this topic
