Kembara Gearbox Leaking
laladude19
Posted 19 February 2017 - 03:36 PM
laladude19
    3rd Gear
  • 3 posts
Hello,
Lately my Perodua kembara Gearbox has been leaking transmission fluid. Its an automatic Gearbox. In the beginning, I was experiencing sluggish transmission. It took 4-5s for the Gear to change from P to D. I took it for maintenance and it was fine.
After repairing it, now it's leaking, I took it back to the same foreman. He told me that the gearbox is leaking. He told me it cant be fix and I had to change 1 which would cost around RM2.5k. According to him, the Housing of the Gearbox is leaking.
Can anyone advice me? Can it be fixed rather than changing a new Gearbox?
Thanks.
Posted 20 February 2017 - 07:42 AM
  • 70,304 posts
Get a second opinion from another foreman. If gear box housing damaged then you will need a new gear box but why did it break after gear box repairs?
laladude19
Posted 20 February 2017 - 02:20 PM
laladude19
    3rd Gear
  • 3 posts
Hello..
After the repair.. Every thing was fine, the car moved smoothly.. Then about a week later.. The oil spot started to appear again.. So I took it back to the same foreman.. He then told me the housing is leaking and need to change a new 1..
Will those sealer conditioner work if I try those?
Thanks..
Posted 20 February 2017 - 07:50 PM
  • 70,304 posts
Hello..
Thanks..
If gasket leak, probably that can help, but your mechanic say housing, means the gear box itself. That is why I mention try getting 2nd opinion see where it is actually leaking.....
laladude19
Posted 20 February 2017 - 10:27 PM
laladude19
    3rd Gear
  • 3 posts
Ohh okay..
Thank you for the advice.. Will checkout another foreman and see how things go..
Posted 21 February 2017 - 07:37 AM
  • 70,304 posts
Ohh okay..
Usually the gear box will be intact unless something hit it. If gasket leak, can just change, that is why need to know actually where it is leaking from. Let us know your results from 2nd opinion or after it has been repaired....
