Toyota Harrier 2.4G Vibrates At Idle!?!
littlegreyharrier
Posted 02 August 2016 - 11:02 PM
littlegreyharrier
  • 8 posts
Hi all gurus, My 06 harrier 2.4G vibrates at idle with D engaged, rpm around slightly more than 500rpm with aircon on. With N engaged, the vibration will go away. With aircon off with D engaged, the rpm is stabilised at 500rpm with no vibrations. Engine mounting, suspension, throttle body cleaning, maf cleaning all have been done. Hopefully one of you gurus can assist. Thanks!
Posted 03 August 2016 - 09:59 AM
  • 71,256 posts
Can tune idling higher when in D? Look likely compressor got load, since with air con off no vibration....
littlegreyharrier
Posted 03 August 2016 - 03:19 PM
littlegreyharrier
  • 8 posts
unsure if the idling can be tune higher. i was told its e-throttle so can't really adjust the low idle rpm.
Posted 03 August 2016 - 08:26 PM
  • 71,256 posts
Oh! you asking the same thing here. If cannot tune then check hoses for leak and/or whether the FICD working or not. When air con kicks in, the Fast Idle should work to compensate the load
littlegreyharrier
Posted 03 August 2016 - 09:23 PM
littlegreyharrier
  • 8 posts
Oh! you asking the same thing here. If cannot tune then check hoses for leak and/or whether the FICD working or not. When air con kicks in, the Fast Idle should work to compensate the load[/quote]
whats the FICD? is it the IACV? thanks
Posted 04 August 2016 - 08:26 AM
  • 71,256 posts
Yup, called differently. Some call stepper motor, servomotor, FICD, IAVC......idling speed is control by ECU so when extra load the valve will compensate the idling speed up
limcw8067
Posted 17 September 2016 - 09:17 PM
limcw8067
Hi Peter,
I am an ex-owner of a '07 Toyota Harrier 2.4G. Back in 2014, my Harrier suffered the same problem
as yours. My problem arised from when my battery went dead, my idiot just "cabut battery" & replaced
a new one. Subsequently, the car suffered low rpm when in D (and when aircond is ON), brake pressed
and when stop at traffic light. The car will vibrate, rpm fluctuates before it stabilize back.
My cure was to clean the throttle body. For the 1st cleaning work, it was done by the same idiot mechanic.
Symptoms persist, Then I went to Auto Vision located at Sunway PJS 11 for the 2nd & "thorough" cleaning,
after which the problems were solved.
However, I remember about 6-8 months later, the symptoms recur, albeit only occasionally. By that time, I was
about to upgrade to Lexus RX350. So finally traded in my '07 Harrier.
Look like this is a common problem in Harrier. In fact, when shopping around for RX350 (V6 engine), I found out even
Lexus RX270 (pre-facelift version, inline 4 cylinder engine like Harrier) suffers the same issues.
Hope this helps.
