[Q] Rough Windscreen
Cybreed
Posted 29 July 2016 - 05:15 PM
Cybreed
  • 256 posts
  • Interests:some things
Recently I had a bad experience when sending my car for respray. Long and horrible experience.
Anyways after I got my car back, the windscreen feels like there are some sort of coating on top of it. It was no longer smooth as before I sent it in for respray. When I use my silicon wipers, it sounds like its going over something rough.
Any techniques to gain back the smoothness which can be DIYeD?
Complain on the present, Blame it on the past.
Posted 29 July 2016 - 11:22 PM
  • 70,781 posts
Try using a claybar. You probably have paint over spray on your windscreen
Cybreed
Posted 30 July 2016 - 08:26 AM
Cybreed
  • 256 posts
Yea, I think so, clear coat maybe. not even 6 months some areas crack dy .. sadness
Averagely how much does a claybar cost, and quality all about same right ?  or any preferred over another
Posted 30 July 2016 - 03:55 PM
  • 70,781 posts
Easiest for you to get should be PG claybar, which is sold in most supermarket or hypermarket. It is around RM30 a box.
The thing is you can cut into 2 or 3 pieces depending on your hand size. Press it flat then use a shampoo solution as lube, then go over the windscreen with a little force. If dirty just fold the claybar then flatten again and continue. Claybar can be used for a long long time. Just don't drop it onto the ground where it might pick up some fine stones/pebbles which can/may scratch the area you clay.
Cybreed
Posted 01 August 2016 - 12:15 PM
Cybreed
  • 256 posts
Okay, thank you for the information
Posted 01 August 2016 - 08:48 PM
  • 70,781 posts
You are welcome.....
goohtj
Posted 02 August 2016 - 11:17 AM
goohtj
  • 104 posts
l use steelwool. cheap n effective . did it on all glass windows.. no worry on scratching glass.
my way
1. wash screen n dry.
2. rub using steelwool until smooth
3. clear away steelwool residue
4. apply rainx 3 layers
done
Posted 03 August 2016 - 08:29 AM
  • 70,781 posts
Wah! 3 layers....... :o
Cybreed
Posted 05 August 2016 - 08:19 AM
Cybreed
  • 256 posts
my way
done
steelwool.. as in those use for washing dishes?
Posted 05 August 2016 - 09:53 AM
  • 70,781 posts
Not sure about steelwool but those green scrubbing pads, can leave some fine scratches......
