Electronic Fuel Injection Fuse Blown.
khairulasnawi
Posted 29 July 2016 - 11:25 AM
khairulasnawi
Why EFI Fuse can blown? is it serious or minor case?
Car : perodua Alza.
Posted 29 July 2016 - 11:20 PM
  • 71,101 posts
After you have replaced the fuse and everything is fine then probably an electric surge only to blow the fuse. If the replacement fuse also blow then you need to check thoroughly.....
khairulasnawi
Posted 01 August 2016 - 11:40 AM
khairulasnawi
Thanks,
if alternator overload, can it cause EFI fuse blown?
Posted 01 August 2016 - 08:47 PM
  • 71,101 posts
Usually for alternator there is a voltage regulator controlling the current. As mentioned, if now okay then leave it
