Vios Parking Brake Illuminated On Dashboard When Handbrake Is Not Pulled
mych
Posted 16 April 2016 - 08:40 PM
mych
  • 7,788 posts
Anyone experienced this issue before? Replaced the brake pads and still it comes out.
Mych
2420l
Posted 17 April 2016 - 06:25 PM
2420l
  • 631 posts
have u checked the brake fluid level?? most probably brake fluid level low
Posted 17 April 2016 - 08:26 PM
  • 70,145 posts
Yup, check the brake fluid level, but usually after changing to new pads which are thicker the brake fluid level should have come back up unless there is a leak some where. The fluid level comes back up because the brake piston are being pushed back into the calipers.
Another thing to check is the switch at the hand brake lever. If the switch is faulty, will show the brakes on even though not.....
