cruisader
Posted 27 December 2015 - 11:50 PM
cruisader
hi every sifu,newbie here,just joined this forum 10 minute ago
just bought my Proton waja last 6 month, the FC is 10km/L but most people Waja can up to 12km/L to 16km/L
i wonder if my car need some improvement or service.
Detail of my waja:
2001 4g18 1.6cc
14 year old
230k ODO
no modification
Engine oil:Mobil 1 multigrade 15W-40 changed from hi-rev 20W-50 slightly improved FC
Ron 95 shell/petronas usually pump full tank and use till almost light up
60% city 40% highway
90/100km/h on highway 50km/h on city (average) is it too fast? or it considered light footer?
no extra weight carried exclude myself(90kg) lol
tyre(Bridge stone) 15" original rim too
thx sifu for advice
Posted 28 December 2015 - 08:00 AM
The FC is higher could be due to the age of the car which is alredy 14 years and have clocked 230k km. You changed from 15w-40 to 20w-50 which is a heavier old and you get better mileage? If you engine is not consuming engine oil you should try 10w-40 Semi Synthetic oil.
It is not only the top speed that consume more fuel, it is the acceleration also. Try to accelerate slowly from stand still especially when driving in town/city
One question, is your car auto or manual? Auto FC will be higher due to power lost in torque converter......
cruisader
Posted 28 December 2015 - 02:27 PM
cruisader
oh yea forgot to mention its Auto,thx for the tip will try for 10W-40 after this, does the semi-synthethic oil good for my waja? since it old.
btw its 20W-50 to 15W-40
Posted 28 December 2015 - 03:34 PM
Oh! if 20w-50 to 15w-40 then will be better mileage as the oil is lighter. End number is the weight of your oil when hot, so 50 is thicker, changing to 40 is lighter. The 15w-40 should be Mobil Super 1000 mineral oil. Not sure you will get better mileage with the Super 2000 SS 10w-40 as hot time still 40 weight. Since your engine is old and have clocked 230k km I won't recommend going to 30.
Other than that you can give the car a good tune up, probably change the plugs if you have not done for a long time and remember to change your ATF also since you mentioned is Auto.....
cruisader
Posted 28 December 2015 - 07:10 PM
cruisader
how long can a spark plug work until it need to replace?is that ATF is auto oil? just changed auto oil last month
Posted 29 December 2015 - 07:40 AM
Check your car manual if you still have it. If not, normal plugs usually 20 to 30k km, Platinum probably 50k, Iridium good till 80k and the Iridium tough said to reach 100k.
Yes, ATF is auto transmission fluid. Maintenance schedule usually every 20k km oil pan change, every 60k km flush and 100k km ATF filter change.
cruisader
Posted 29 December 2015 - 07:37 PM
cruisader
appreciate all the advice, Thanks
Posted 30 December 2015 - 07:43 AM
rallychamp
Posted 30 December 2015 - 11:09 AM
on the other hand if u want something better than stock factory...
try look for mxsteven: https://www.facebook...361641300680715 and reflash your ecu with better than stock factory mapping.... especially the spark plug coil dwell time...
cruisader
Posted 30 December 2015 - 01:09 PM
cruisader
any suggest at rawang or kota damansara?ECU is circuit tuning?so need to go for big factory?
btw is that waja stock factory not that good?
