KrisMas
Posted 07 October 2015 - 10:56 AM
Need urgent advice/recommendation.
Some details:
Car: Chery Eastar 2.0
Year Made: 2008
Age of car: 5 yrs
Mileage: 120 000 km
Transmission: PSA DP0
ATF: Elf Renaultmatic D3 Syn
I was doing some maintenance/cleaning of the transmission valve block (valve body) the other day and noticed that one of the wire going to the solenoid valve is damaged. Anybody know any fix without requiring to replace the whole set of wire harness?
TIA
Posted 07 October 2015 - 02:42 PM
If only the casing can just wrap them back?
rallychamp
Posted 07 October 2015 - 04:16 PM
KrisMas
Posted 07 October 2015 - 04:52 PM
Under normal circumstances, I would just cut the wire, insert a heat shrink sleeve, solder the wires then cover it with the heat shrink. But I don't know whether it's safe to do that considering it's inside a sealed transmission and susceptable to high heat and also high temp ATF.
KrisMas
Posted 07 October 2015 - 05:03 PM
I've been googling around and found out that there is such a thing as high temperature chemical resistant heat shrink. Will I be better off using that and, if so, anybody know where I can find it?
Posted 08 October 2015 - 09:08 AM
The wire inside the transmission? Pictures shows it is on the outside.
Not sure where to get high temperature heat shrink
KrisMas
Posted 08 October 2015 - 03:02 PM
Sad to say....yes. Technically it is inside the gearbox, behind the valve body. I opened the cover with the intention to service/clean the transmission hydraulic block (valve body) due to some irregular/irratic jerking when shifting gears and incidentally found it after removing the hydraulic block.
Btw, how's your Tiggo running? Any major problems (yet)?
Posted 09 October 2015 - 08:18 AM
Mine lower mileage, around 50+k km only. About 1 year old time, had gear lever issue. Could not engage reverse, they change the cable. Later something similar happen they change the whole gear assembly.
Lately check engine light came on and idling rough. Send back for scan they say oxygen sensor, so they clean and reset. Mention if same thing comes back need to change the sensors.
Other issue are poor rubber quality. The roof top aerial failed and rubber base crack. The front windscreen rubber lining also crack and peel. Other than that all okay,
Since yours already 120k km, when did you change the timing belt? Oh! wait, yours is 2008 model how come 2.0L? Those days not the 2.4L Mitsu engine. I remember waiting for the Acteco engine which is 2.0L in 2010
KrisMas
Posted 09 October 2015 - 09:48 AM
Good to hear that...no major problems.
Changed my timing belt at around 80k km. Warranty was over at that time so I bought the timing belt set myself and send it to a workshop outside (ex-Chery mechanic) for the installation.
Ooops...should have said 2008 is for the transmission (based on the identifications). The car itself is 2010 model with the Acteco engine and I chose the model without the sunroof (when I got to know beforehand that the sunroof is actuall aftermarket).
Posted 09 October 2015 - 06:31 PM
Oh! Yours changed at 80k km. The SC ask to change since ours is 50k km, but then already 5 years, so more or less time to change already because I broke my Accord one last time. 40k km only but car already 5 years old that time
