Waja 1.8 - Finally The Engine Gave Up
Posted 20 August 2015 - 10:29 AM
Posted 20 August 2015 - 11:54 AM
After 13 long years, my waja 1.8 is due for a transplant. Aircond is down and suddenly the touch pad was out.. decided that a transplant is better than fixing the renault engine. Shopped around and decided on one in Damansara Damai which is nearer to my place and his ads which is always in mudah. Will continue to give update here on the transplant.
aircond and touch pad faulty then need to transplant engine?
btw, what is touch pad?
Posted 21 August 2015 - 08:05 AM
Yah! was about to ask the same thing?
Posted 21 August 2015 - 08:07 AM
What engine can you transplant in? Does the Renault engine have same engine mounting as the Mitsu engine?
Posted 21 August 2015 - 12:57 PM
I need to repair the touchpad. Waterhost leaking. Aircond. Gearbox slipping if lack pressure (engine cold). Selling will still be difficult with low value. Hence, decided to transplant with mivec engine.
Posted 25 August 2015 - 04:10 PM
Touchpad is the security sensor
was it a cobra module? like a stick sometime after 1 min no start engine need to touch it in order to start?
seems similar module like older toyota cars?
