We are change our cars in oder to improve performance, speed, power and so on. So the high performance tuning parts ars necessary.
Like, conrods,crankshaft, cam gears, turbocharger, suspension coilovers, intake & exhaust manifold, ignition coils, pulley etc.
Car Tuning Parts
gears11
, Jan 30 2015 03:10 PM, 1 reply to this topic
Posted 30 January 2015 - 07:02 PM
QUOTE (gears11 @ Jan 30 2015, 03:10 PM) <{POST_SNAPBACK}>
Mmmmm....... why not change your brain first ? before you type any words here !! who will change daily car set up to racing spec hardware ? when with those modified parts will cost you as almost another car price.. unless your money are growing on the tree.. or you are modify mainly for track racing... or you are just like me, an stupid idiot that spend all money on car then at the end it still a junk..
The true motor racing hardcore will not easily change their track set up if the car performance had been well suited as per track requirements & condition.. only when competition level been raised by others competitors then only will consider improvement of new hardware or software as these thing don't come with cheap price tag... so are you track kaki ?????
