Hi all,
having a peugeot 308 vti, the aircond problem cant solve after checking at glemarie and puchong service center.
here is the problem description,
the aircond sometime cold and some time no, when the car is start than switching on aircond the fan didnt kick in, as normal we will heard the loud fan sound. i have tried after started the car and wait about 15 minute let the temperature raise untill half and try to switch on aircond, mostly the aircond work(cold). if the aircond was worked sometime half way driving it will suddenly not working again...
any sifu know what is the problem? have already insert gas and changed aircond relay. 1 of the service center told me it is cooling coil problem. but i have checked with outside workshop, the gas no leaking, and if the cooling coil problem why is it will sometime cold sometime not?
any workshop recomended for this case in selangor?
Thank you.
Peugeot 308 Aircond Problem Sometime Hot Sometime Cold
sky6881
, Jan 19 2015 08:51 PM, 2 replies to this topic
