I found an old topic on this forum covering the same issue but I couldn't find the solution for this.
Sound:
* Front RH (Driver side)
* Like mineral bottle or empty can hit into something solid.
* Intermittent. On bump but more frequent when goes uphill
What have been changed:
* Front Strut into KYB
* Front mount.
What haven't been changed:
* Ball joint *
* Inner tie road
* Outer tie road
* CV Joint
* CV Shaft
* Bottom RH Engine mount (hydraulic) * Note: there is around 3-5mm gap to the base. Not sure if this enough. But I have tried to shake the engine by putting into first gear and handbrake but can not generate noise.
* Top RH Engine mount (torque arm/ dog bone shape) *
* Top spring cushion (against the top mount) *
* Bottom spring cushion
Any idea please please help. I love my car but this noise is so annoying.
Clunk Knock Sound On Civic 8th Gen
riftan
, Jan 08 2015 06:22 AM, 1 reply to this topic
Posted 02 February 2015 - 11:23 AM
Where do you sent ur car for those checking? u can always refer to the honda service centre..the gap is acceptable..sometime its just nothing to do with those parts u wanna change..noise is something hard to detect and it need time if you sent to the right place...
