Migrated Topic: Wash Engine
Karl_Erik_Chee
Posted 18 September 2004 - 01:04 AM
Karl_Erik_Chee
  • 904 posts
tjk
About Me posted on 8-Sep-04 11:19 [edited 0 times] [edit] [delete]
members,
i drive altis. have heard that do not wash the engine - just wiping it
with a damp cloth shall do the work.
is this true ? or is there any trusted and experienced place where they
can perform a good engine wash ?
thanks.
Reply Messages Complaint
isetop
About Me posted on 8-Sep-04 12:00 [edited 0 times] [edit] [delete]
Now days, most car engine a equip with electronic parts,electric and
water
don't mix..if mix short circuit might happen.Suggest to use of the shelf
engine spray cleaner.
megatnh
About Me posted on 8-Sep-04 12:28 [edited 0 times] [edit] [delete]
hi
if u wanna wash the engine ,cover the electrical parts 1st and dont use
high pressure water.use engine degreaser and hose off with flowing water.
probably a good idea to cover the belting as well.water and belts dont
get
along together
warm-up the engine after wash to get rid of any moisture.perhaps drive it
around your housing area; this is to blow air into the engine compartment
hope that helps
meg
cash
About Me posted on 8-Sep-04 21:22 [edited 0 times] [edit] [delete]
I use strong air jet to clean the engine compartment.
tjk
About Me posted on 9-Sep-04 10:49 [edited 0 times] [edit] [delete]
Suggest to use of the shelf engine spray cleaner.
So, after spraying, clean with a dry cloth, is it ?
tjk
About Me posted on 9-Sep-04 10:51 [edited 0 times] [edit] [delete]
use engine degreaser and hose off with flowing water. probably a good
idea
so, the engine degreaser can be applied almost on any of the parts inside
the engine ? also, what do you use to cover those areas inside the engine
that you would not want to touch water or the degreaser ?
Thanks.
tjk
About Me posted on 9-Sep-04 10:53 [edited 0 times] [edit] [delete]
can those air-pressure thing (which look like a can of aerosol) work ?
where to get the air-jet ?
how bout for those areas where there are grease or oil stain ? these
cannot be removed by the air-jet. any help ?
thanks.
megatnh
About Me posted on 9-Sep-04 17:00 [edited 0 times] [edit] [delete]
hi tjk
spray the engine degreaser to get rid of the oily/greasy stuff on the
engine, let it soak a while.you probably have to brush off the stain area
prior to hosing it off with the water.i normally cover the electrical
part
with the plastic wrap (the one that comes in rolls).repeat the process in
the event the oily area remains
meg
cash
About Me posted on 11-Sep-04 3:22 [edited 0 times] [edit] [delete]
--------ow. I\'XX4S3s (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('10927', '', '676', 'Karl_Erik_Chee', '218.208.87.90','1095441058', '1081', 'Migrated Topic: spray painting', '1', 'Karl_Erik_Chee', 'dd0dbb0976dad1fc05a28ae8c3db5dac', '', 'rfbu\n\nTotal Posts: 1597\nMember Since: 10-Dec-2002\nAbout Me posted on 7-Sep-04 11:34 [edited 0 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\nmy car has metalic paint \n\nrecently, my car bashed into another car \n\nnow, i need a paint job. \n\nbeing a stingy poker like I am, is it possible just to spray the affected \npart? maybe just a few square inches. if i get just the affected part \nsprayed, can the difference be noticed? \n\nI hear it\'s necessary to spray the entire car, is that true? \n Reply Messages Complaint \n \nMidNiteOil\n\nTotal Posts: 232\nMember Since: 16-Jan-2004\nAbout Me posted on 7-Sep-04 16:23 [edited 1 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\nThe smallest panel you can spray alone is the fuel lid panel. \n\nFor example,Let say you banged one of your doors,you need not to spray \nthe \nentire car! Just enough to spray for just one door. However, on certain \ncase,some doors may have been divided by a door-guard-strip, you probably \ncan \njust paint half the door upper or lower of the d-g-strip! Similarly to \nbumper, no need to spray other panels such as boot lid or bonnet if just \nthe bumper spoiled by the accident.. \n\nAnyway, the painter knows what best for you and your car! Just ask their \nopinion!\n---------------\n\nWhoops!!\n \n Reply Messages Complaint \n \nrfbu\n\nTotal Posts: 1597\nMember Since: 10-Dec-2002\nAbout Me posted on 7-Sep-04 20:15 [edited 0 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\n10q 10q \n Reply Messages Complaint \n \n','Karl_Erik_Chee@1');498INSERT INTO ibf_posts (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('10927', '', '676', 'Karl_Erik_Chee', '218.208.87.90','1095441058', '1081', 'Migrated Topic: spray painting', '1', 'Karl_Erik_Chee', 'dd0dbb0976dad1fc05a28ae8c3db5dac', '', 'rfbu\n\nTotal Posts: 1597\nMember Since: 10-Dec-2002\nAbout Me posted on 7-Sep-04 11:34 [edited 0 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\nmy car has metalic paint \n\nrecently, my car bashed into another car \n\nnow, i need a paint job. \n\nbeing a stingy poker like I am, is it possible just to spray the affected \npart? maybe just a few square inches. if i get just the affected part \nsprayed, can the difference be noticed? \n\nI hear it\'s necessary to spray the entire car, is that true? \n Reply Messages Complaint \n \nMidNiteOil\n\nTotal Posts: 232\nMember Since: 16-Jan-2004\nAbout Me posted on 7-Sep-04 16:23 [edited 1 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\nThe smallest panel you can spray alone is the fuel lid panel. \n\nFor example,Let say you banged one of your doors,you need not to spray \nthe \nentire car! Just enough to spray for just one door. However, on certain \ncase,some doors may have been divided by a door-guard-strip, you probably \ncan \njust paint half the door upper or lower of the d-g-strip! Similarly to \nbumper, no need to spray other panels such as boot lid or bonnet if just \nthe bumper spoiled by the accident.. \n\nAnyway, the painter knows what best for you and your car! Just ask their \nopinion!\n---------------\n\nWhoops!!\n \n Reply Messages Complaint \n \nrfbu\n\nTotal Posts: 1597\nMember Since: 10-Dec-2002\nAbout Me posted on 7-Sep-04 20:15 [edited 0 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\n10q 10q \n Reply Messages Complaint \n \n','Karl_Erik_Chee@1');s9ȥȥhf]
MidNiteOil
the
can
opinion!
Whoops!!
rfbu
10q 10q
crlrfbu\n\nTotal Posts: 1597\nMember Since: 10-Dec-2002\nAbout Me posted on 7-Sep-04 11:34 [edited 0 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\nmy car has metalic paint \n\nrecently, my car bashed into another car \n\nnow, i need a paint job. \n\nbeing a stingy poker like I am, is it possible just to spray the affected \npart? maybe just a few square inches. if i get just the affected part \nsprayed, can the difference be noticed? \n\nI hear it\'s necessary to spray the entire car, is that true? \n Reply Messages Complaint \n \nMidNiteOil\n\nTotal Posts: 232\nMember Since: 16-Jan-2004\nAbout Me posted on 7-Sep-04 16:23 [edited 1 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\nThe smallest panel you can spray alone is the fuel lid panel. \n\nFor example,Let say you banged one of your doors,you need not to spray \nthe \nentire car! Just enough to spray for just one door. However, on certain \ncase,some doors may have been divided by a door-guard-strip, you probably \ncan \njust paint half the door upper or lower of the d-g-strip! Similarly to \nbumper, no need to spray other panels such as boot lid or bonnet if just \nthe bumper spoiled by the accident.. \n\nAnyway, the painter knows what best for you and your car! Just ask their \nopinion!\n---------------\n\nWhoops!!\n \n Reply Messages Complaint \n \nrfbu\n\nTotal Posts: 1597\nMember Since: 10-Dec-2002\nAbout Me posted on 7-Sep-04 20:15 [edited 0 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\n10q 10q \n Reply Messages Complaint \n \n9INSERT INTO ibf_posts (pid, edit_time, author_id, author_name, ip_address, post_date, topic_id, post_title, new_topic, edit_name, post_key, post_parent, post, old_UserID) VALUES ('10927', '', '676', 'Karl_Erik_Chee', '218.208.87.90','1095441058', '1081', 'Migrated Topic: spray painting', '1', 'Karl_Erik_Chee', 'dd0dbb0976dad1fc05a28ae8c3db5dac', '', 'rfbu\n\nTotal Posts: 1597\nMember Since: 10-Dec-2002\nAbout Me posted on 7-Sep-04 11:34 [edited 0 times] [edit] [delete] \n\n--------------------------------------------------------------------------\n------\nmy car has metalic paint \n\nrecently, my car bashed into another car \n\nnow, i need a paint job. \n\nbeing a stingy poker li
