QUOTE (intheshed @ Nov 22 2014, 08:30 PM) <{POST_SNAPBACK}>
Wife arrived home to tell me she broke the car again!
Drivers door window was stuck down and wouldn't go back up.
She tried "pushing" the switch a few times [more likely belted the living daylights out of it]
I stripped the door to test the motor and it worked both up and down if 12 volts was applied directly [bypassing the switch]
- but I found a lot of little bits when I took the door skin off.
The switch had fallen apart inside the door panel - luckily all the springs, metal rocker pieces, plastic rods
and the bottom cover plate were all trapped between the door trim and the plastic dust sheet that is glued to the door.
I spent an hour or so figuring out how the switch goes back together - and gave it a little grease in a few spots, then put
everything back together.
It all seems OK for now - and if it happens again, I could rebuild the switch in a few minutes - as long as none of
the tiny parts don't get lost.
Anyone know if these switches are common with any other vehicles - or are they a "Proton S16 / SAGA specific item".
stephen
stephen
not sure...but can cross check with other proton car models....
or last resort...super glue all the things!
