Steering Problem
Gunnerzz
Posted 06 June 2014 - 10:38 AM
Gunnerzz
  • 3,102 posts
QUOTE (vr2turbo @ Jun 6 2014, 08:06 AM) <{POST_SNAPBACK}>
To me it is not related, but since suspension already need to repair, might as well change and see if it does anything to your steering problem... smile_tongue.gif
well.....its an old car.
i would guess the steering rack is worn out.
when the road is uneven,the pressure exerted by the road surface causes the rack to move.
movement is minimal but the effect is significant.
i am driving a waja but the problem is similar.
at first os suspect the lower arm and the steering rack bush mount is worn out but its not the problem.
i even remove the lower arm and brought it to spare part shop but the shop refuse to sell to me saying that nothinf is weong with mine.
how i know its the steering rack?
i jack the front until the wheel is off the ground,turn the steering wheel left and right.
i notice the same tok3 sound when i am going on uneven road.
i put my hand on the tie road and can feel a knocking feeling and the freeplay of the rack.
the tie rod itself is in good shape.
yazir20
Posted 06 June 2014 - 02:16 PM
yazir20
  • 22 posts
Hmm wokey...thanks dude
nancylong
Posted 30 September 2014 - 07:49 PM
nancylong
    Driver
  • 49 posts
  • Gender:Female
Steering is a critical component of driving. Turns are a steering issue many drivers face. It is all about practice.
automotive repair services
ahtrac777
Posted 19 November 2014 - 08:33 PM
ahtrac777
Get it repaired by a good mechanic.
limking
Posted 15 December 2015 - 03:05 PM
limking
  • 2,887 posts
My friend's Camry 2.0 also faced the same problem after changing to new tyres .Did normal wheels balancing & alignment then .Brought him to see my mech & did high speed balancing on both front wheels .Pesto ! problem solved .
Posted 16 December 2015 - 07:54 AM
  • 71,444 posts
Normally if rims, tyres etc have no problems, off wheel balancing should do the trick.....
