Volvo S60 Or S80
jerrylauck
, Apr 20 2014 04:35 AM, 7 replies to this topic
Posted 20 April 2014 - 04:35 AM
Hi need some pro advice here. I am thinking to get a volvo car. 1st choice is comfort. I am not sure shall i consider S60 or S80 year 2011 model. I am concern how reliable the car. I dont have any friends driving volvo so i cant get any accurate information. What common problem of volvo car and what the major problem. Which model is more reliable? I hope you guy can reply me. Thank you very much
Posted 22 April 2014 - 10:38 AM
QUOTE (jerrylauck @ Apr 20 2014, 04:35 AM) <{POST_SNAPBACK}>
if you are not after power band but instead comfort then S80 2.5T are ideally for you, as this car are so comfort but some just said it's too comfort until it become boring... this car don't have much problem as I know as its the improved version of the first generation of S80.. BUT regular service for Volvo is essential as these car are designed mainly for cold country so our extreme hot weather here will eventually kill the parts sooner than what Volvo thought. so don't blindly follow what the Volvo recommended service scheduled.
since you intend to get used 2010 unit that have warranty expired.. better send the car that your like back to authorized service center ( federal auto ) to performance the inspection that will only cost your rm1xx and it came with full report of the car condition and recommendation. and if the car are bad then just give it out until you find the ideally unit.. my last advise is buying used Volvo need to be patient.
Posted 22 April 2014 - 11:22 AM
but if you are looking for comfort 1st. then Volvo's are champs. Amongst conti, they are the best.
if you have reliability as second, you may need to look elsewhere. the parts are really pricey as they dont have demand for them..
what is your budget? you can get a brand new S60 with 5 years warranty and service. it is very comfortable.
reliability isnt great as it shares it parts with Ford.
Posted 22 April 2014 - 05:28 PM
QUOTE (jamespaul @ Apr 22 2014, 11:22 AM) <{POST_SNAPBACK}>
wonder what parts are sharing between Volvo and Ford ? .......beside the engine.
Posted 22 April 2014 - 06:03 PM
QUOTE (V406198 @ Apr 22 2014, 05:28 PM) <{POST_SNAPBACK}>
gearbox
City stop tech
Blind spot tech
Chassis / platform
and others that i am not aware of.
Posted 23 April 2014 - 09:58 AM
QUOTE (jamespaul @ Apr 22 2014, 06:03 PM) <{POST_SNAPBACK}>
gearbox
City stop tech
Blind spot tech
Chassis / platform
City stop tech
Blind spot tech
Chassis / platform
infact ECU ME9 are similar as well as from same source
Posted 23 April 2014 - 12:54 PM
QUOTE (V406198 @ Apr 23 2014, 09:58 AM) <{POST_SNAPBACK}>
but the Ford uses a slightly older version vs. the Volvo one.
the Volvo City stop can stop up to 55km/h, where as the Ford on is only up to 35km/h (plus minus)
Posted 24 April 2014 - 10:48 AM
QUOTE (jamespaul @ Apr 23 2014, 12:54 PM) <{POST_SNAPBACK}>
O.. sorry i'm compare apple to apple interns of similar models of both Volvo and Ford, example like current S60 T5 Vs Ford Mondeo that both are on similar power output/performance..but is just the mapping for both are slight different.
