Just changed to Prestone brand coolant for my Proton Persona today. Radiator & spare tank need approx. 3.4 liters of this pre-mixed 50/50 ratio, so no water to be added.
Since 1927 when the Prestone® brand first introduced Antifreeze/Coolant for automobiles, people have trusted the Prestone® name for outstanding protection in their car's cooling systems. Today's cars and light-duty trucks are more complicated than ever. Antifreeze/Coolants come in a variety of colors and chemistries. So which one is right for your vehicle?
Prestone® Extended Life Antifreeze/Coolant is compatible with ANY antifreeze/coolant – regardless of color – for use in ALL makes or models of cars and light duty trucks. This patented formula provides a high degree of performance durability and carefully balanced protection against temperature extremes and rust and corrosion of all cooling system metals, including aluminum.
Prestone® 50/50 Ready-to-Use Prediluted Extended Life Antifreeze/Coolant is a blend of 50% antifreeze/coolant for temperature and corrosion protection and 50% demineralized water for heat transfer protection.
Prestone® Extended Life Antifreeze/coolant For My Proton Persona
comanche91
, Mar 30 2014 12:07 AM, No replies to this topic
Posted 30 March 2014 - 12:07 AM
If you make a habit of buying things you do not need, you will soon be selling things you do - Filipino Proverb
