Aircond Problem
Posted 08 March 2014 - 07:05 PM
the problem wont happe if i am cruising.the relay is ok as it turn the fan on,no problem with ecu as it send signal to the compressor and raises the rpm.
one shop said its the clutch and quote at least rm350 for the repair.
any other suggestion?
my aircond is super cool when running.
Posted 09 March 2014 - 10:15 AM
Yup, probably the magnetic clutch faulty.....
Posted 09 March 2014 - 03:10 PM
it do make sense.
what i dont understand is that it will kick in if i rev it to 4200rpm.
shoul i just replace the clutch or do an overhaul?
Posted 10 March 2014 - 07:42 AM
Overhaul the compressor? If nothing else is wrong just repair the fault and that is to replace the clutch. But once opened up need to re-oil and recharge the gas.
Posted 19 March 2014 - 01:31 PM
nope.
i have to put the repair in hold as i just got married and need to restructure the budget...heheh
i can live with it as my route mainly involve cruising.
Posted 20 March 2014 - 09:08 AM
Congrats to you, bro. Gunnerzz
Posted 20 March 2014 - 09:34 PM
tq bro.....
now the water pump starts to make noise.
i tot marriage brings new challenge but i guess its the same...replacing worn out part
Posted 21 March 2014 - 07:56 AM
Your car got angry now that you have another love in your life....hahahaha
Posted 22 March 2014 - 02:13 AM
usually, it is due to the gap between the clutch and magnetic coil is slight too big. if you are lucky, just unbolt the clutch and remove some washer.
if not, will be the coil. why revving to 4200rpm will engage it because the voltage will be higher at that rpm.
tazztham
