Timing Belt Or Chain.
tkhoo
Posted 14 July 2013 - 04:19 PM
tkhoo
  • 54 posts
All sifu,
May I know below statement true or not? Duratec engine use timing chain?
Zetec engine's belt is good for 100k miles no problems.
Duratec engine's belt is a chain.
Anyone here change the chain before? As I heard that chain no need to change till we hear metal rub sound than it time to change, am I right?
Breadman
Posted 14 July 2013 - 06:00 PM
Breadman
  • 3,172 posts
Duratec uses timing chain. No need to change.
Watch this video:
For engines using a timing belt I will change at about 75k even if the manufacturer recommends 100k.
"Behind every great fortune there is a crime." ~ Mario Puzo (The Godfather)
tkhoo
Posted 14 July 2013 - 06:21 PM
tkhoo
  • 54 posts
QUOTE (Breadman @ Jul 14 2013, 06:00 PM) <{POST_SNAPBACK}>
Watch this video:
Focus sifu,
Nice to hear from you. That mean all the Focus that selling at mudah.com.my with 2.0L hatchback with duratec engine, am I right? So from your experience, when will be the time to change the chain?
Actually now I gather more information what should I need to prepare to change if get a used Focus 05/06.
Thanks in advance.
Breadman
Posted 14 July 2013 - 06:53 PM
Breadman
  • 3,172 posts
Ya, all the Focus MKII petrol models sold here uses timing chain. The chain can last a long time. I hardly hear of people changing this part. Anyway this part is mileage related. Check out the cumulative mileage of the car you intend to buy.
tkhoo
Posted 14 July 2013 - 07:19 PM
tkhoo
  • 54 posts
QUOTE (Breadman @ Jul 14 2013, 06:53 PM) <{POST_SNAPBACK}>
Great to hear the information that I got from internet is 90% right on the timing chain.
May I know this Focus must use particular AMT oil or it can be use any brand? Same as other brand to change the oil every 20-30k km?
Sorry for not gather all the question together. Thanks for your time.
Breadman
Posted 14 July 2013 - 09:49 PM
Breadman
  • 3,172 posts
QUOTE (tkhoo @ Jul 14 2013, 07:19 PM) <{POST_SNAPBACK}>
For ATF you can use Motorcraft Mercon V or any reputable brand of the same grade. As for when to change, different mechanics will tell you differently. Changing every 50k should be OK.
If I am buying a used car I would change all the fluids and rubber belts upon taking delivery. Just a precaution.
tkhoo
Posted 14 July 2013 - 10:19 PM
tkhoo
  • 54 posts
QUOTE (Breadman @ Jul 14 2013, 09:49 PM) <{POST_SNAPBACK}>
May I know Focus use what viscosity & weight for engine oil?
May I know did ATF got any specification like engine oil(viscosity & weight)? If yes, may I know the specification if I can't find Motorcraft Mercon V ATF.
How about brake oil? Can just add with different brand if needed?
Thanks again.
Breadman
Posted 14 July 2013 - 11:21 PM
Breadman
  • 3,172 posts
May I know Focus use what viscosity & weight for engine oil? [Synthetic 5W-40. You can also use semi-synthetic with shorter service interval, say, every 7500 km]
May I know did ATF got any specification like engine oil(viscosity & weight)? If yes, may I know the specification if I can't find Motorcraft Mercon V ATF. [Different rating as engine oil. The rating is DEXRON or MERCON]
How about brake oil? Can just add with different brand if needed? [Don't mix. Stick to same brand and type DOT4]
Thanks again.
tkhoo
Posted 15 July 2013 - 10:10 AM
tkhoo
  • 54 posts
QUOTE (Breadman @ Jul 14 2013, 11:21 PM) <{POST_SNAPBACK}>
Thanks again.
spiceman
Posted 05 August 2013 - 01:01 AM
spiceman
Mr. Breadman,
I just bought 2ndhand Focus 2007, Can you suggest the best mechanic for servicing in Klang Valley.
