Brake Rotor Advise
devils555
, Jun 13 2013 05:00 PM, 7 replies to this topic
Posted 13 June 2013 - 05:00 PM
Hi hi...
I'm thinking of changing my current original rotor but couldn't decide which is better and it seems quite hard to find some of them.
The current market brands
1)Project Mu
2)Dixcel
3)DBA
4)Jun
Anyone had try one of them before...I'm sure Project Mu will have alot of user...I'm currently using Endless Y-Sport pads and I'm looking for a even better rotors...Thanks
1)Project Mu
2)Dixcel
3)DBA
4)Jun
Posted 13 June 2013 - 07:16 PM
Oh! all branded stuffs. I only using cheap Shoji from spare part shop....
Posted 10 January 2014 - 10:23 AM
QUOTE (vr2turbo @ Jun 13 2013, 07:16 PM) <{POST_SNAPBACK}>
When to change it?
If my car (8 years) crushing high speed a bit vibrate ( after alignment & balancing ) is it mean the rotor problem ?
If yes why no shop ever advise me to change ................?
Never change any rotor in my life.......
Posted 10 January 2014 - 10:52 AM
QUOTE (moneyhum @ Jan 10 2014, 10:23 AM) <{POST_SNAPBACK}>
When to change it?
You mentioned vibration during high speed cruising...not during braking.
Based on this, it might not be the rotors.
Check your 4 rims first to ensure they are perfectly round.
Many tyres also become "out of round" as they wear down. These can cause the vibration you mentioned. All the balancing and alignment will not fully rectify these problems.
Posted 10 January 2014 - 02:54 PM
When to change it?
Agree with bro. jklow, the balancing either not done well, or your wheel could be off center and may be dented.
If you hit the brakes and the steering vibrates then your disc rotor is warp. You can send to skim if the disc are still thick, if not then change. But from your explanation it is more of balancing and fitting problem.
Posted 13 January 2014 - 01:01 AM
QUOTE (vr2turbo @ Jan 10 2014, 02:54 PM) <{POST_SNAPBACK}>
My gf's dad Persona vibrates when pressing the brake.. the feeling is greater when >80km/h
Alignment and Balancing guy have checked the rim they are all okay.. they recommend disc rotor...
Went to Proton SC to check and they mentioned the same too... although
*Supposed to claim warranty but it was like just >2 weeks after warranty.. the issue was like 6 months ago and nobody mentioned till i took and drove it last 2 weeks and discovered.. haiz
Posted 13 January 2014 - 09:01 AM
QUOTE (devils555 @ Jun 13 2013, 05:00 PM) <{POST_SNAPBACK}>
Hi hi...
1)Project Mu
2)Dixcel
3)DBA
4)Jun
1)Project Mu
2)Dixcel
3)DBA
4)Jun
JUN? lol.. JUN never make brake parts.. those e-slit rotors are fake.
Posted 13 January 2014 - 09:09 AM
QUOTE (davidlow7 @ Jan 13 2014, 01:01 AM) <{POST_SNAPBACK}>
Wear and tear parts also have shorter warranty periods....
