How Do I Clean Microfiber Cloth
Posted 10 June 2013 - 11:47 PM
Posted 11 June 2013 - 07:38 AM
Brother, for what you explain like your cloth is coated with wax? Is this the cloth for buffing? I wash mine with washing detergent only...
Posted 11 June 2013 - 07:52 AM
Yes bro. Sorry left that out. The cloth is for buffing. I have also tried max kleen9. Doesn't seem to help too. Do I need to scrub the cloth with a clothes scrubber? I don't do that fearing it would damage the cloth
Posted 11 June 2013 - 07:58 AM
Bro, may you share which brand wash detergent you're using? As for me, I'm just using generic dish wash like those being use by hawkers. I'll scrub by hand and soak in the dish wash solution overnight. Subsequently the next day will rinse twice and then soak overnight again in a pail of water with distilled vinegar. So far it seems to be clean enough but am still looking out for better and more effective methods.
Thought of trying the microfiber rejuvenator but its costly. Are there anyone here using it.
How do I get rid of stains on the cloth? Can vanish be used?
Regards
Posted 11 June 2013 - 08:23 AM
Regards
Max kleen and dawn bro.
This is the results.
Posted 11 June 2013 - 08:29 AM
Regards
Just the normal washing detergent my wife buys for washing clothes. Zip, Daia and so on. I soak and scrub by hand only and I try to wash them less as any washing will degrade them. Scrubbing with brush is worse....
Posted 11 June 2013 - 09:21 AM
I don't think it got anything much to do with wax residue. By it's nature, microfiber cloth would bead water because of it's microscopic strands. You'd need to 'break it in', then only it would absorb water. Don't worry too much about it.
Regards
Dish washing liquid would do fine. But try not to soak them for too long. One or two hours enough already. Overnight would be over kill and it might cause the fibers to deteriorate/hardened faster. Rinsing/soaking in vinegar is actually to neutralise whatever detergent left so that it won't harm the mf. No need to overdo that either.
My normal method would be to soak my mfs for around an hour or two, lay it down on a clean floor then spray all the dirt off with my pressure washer or my hose on fan setting....no scrubbing required. So far so good and 95% of the time my mfs would come out looking as good as new. I used to use dishwashing detergent (Sunlight) and it worked fine. But after I got my hand on some micro restore, it does seem to work better....easier to clean and softer after they dry (but maybe just some placebo effect though....hehehe...).
If there are still some stain after your wash, you can try the above method. Don't scrub with a brush though....the strands would definitely get damaged doing that. If still can't get it out, you'd have to live with it. It should be safe for use as those are most probably stain instead of dirt grit. If you're still not comfortable using it, then don't. Get some new ones and delegate the stained ones for 'coarse' uses.
Regards.
Posted 11 June 2013 - 10:33 AM
Posted 11 June 2013 - 03:38 PM
Settled.
Posted 11 June 2013 - 05:27 PM
Your wax/sealant must be very good then! Try finding a cleaner/APC/degreaser/etc that can remove your wax/sealant without much agitation first. As I know most good waxes/sealants are pretty resistant to cleaners (which are mostly alkali based including DG ultimate orange) but not so to acid. One thing vinegar is a pretty weak acid. Talking about it... have not tried Meg's wheel brightener on a MF before...
