New Serena C26 Hybrid
#211
Posted 26 October 2014 - 09:57 AM
Anyone can share the link to gear shift LED? Wanted to buy that.
Thanks.
- Great Minds Think Alike, Fools Seldom Differ
- When a man tells you he got rich through hard work, ask him: whose?
- It's not your salary that makes you rich, it's your spending habits.
#212
Posted 26 October 2014 - 06:18 PM
Got a bit lost in the Rakuten website.
Thanks.
[/quote]
Kat sini.
http://global.rakute...commend_item_en
#213
Posted 01 November 2014 - 09:46 AM
Your CBU tyre got swapped out???
Got my serena 2 days ago.
the ecopia tyres also made in Indonesia.
#214
Posted 02 November 2014 - 06:06 PM
Mine came with visor.
Can share about wind noise in yours?
#215
Posted 13 January 2015 - 05:23 PM
SC say due to electrical board faulty.
#216
Posted 27 April 2015 - 01:03 PM
#217
Posted 17 February 2016 - 01:32 PM
leong9996, air cond hot is related to a bad condenser fan. I had mine replaced and air con back to normal.
You can check by leaving your serena under the hot sun (no shade) from 10am to 11pm. Then open the bonnet, and start the car with air con ON. Go to the engine area and listen for the fan or see if it spins right away. If not, fan problem. If yes, gas problem (or worse).
#218
Posted 20 April 2016 - 09:48 PM
Does anyone know where is the cabin aircon filter is located?
I want to check the filter to see if it need replacement after 2 years.
Thanks.
#219
Posted 20 April 2016 - 11:44 PM
Air con cabin filter are usually near the glove compartment. Either behind, below or at the side. Either that or you try to locate where your blower is, the filter is normally around there
#220
Posted 29 April 2016 - 03:41 PM
Dear All
Is the autolock hidden function mentioned by Sianglee really working for CKD version?
