exora b steering vibration at 110-120 eventhough twice has been on on-wheel balancing.
its my relative's car. could it be the drive shaft the culprit ?
anyone came across this?
thanks.
Exora Steering Vibration
dabdab
, May 14 2013 09:38 AM, 3 replies to this topic
Posted 15 May 2013 - 08:37 AM
QUOTE (dabdab @ May 14 2013, 09:38 AM) <{POST_SNAPBACK}>
thanks.
thanks.
Can be a few things. Drive shaft, rims off center, tyre out of shape, tyre not mounted properly etc...
When do on wheel can see the tyres rotating nicely, means no wobble at all. Slight swaying left/right or have slight up/down movement can cause some vibration when car reach higher speed.
Posted 15 May 2013 - 11:21 AM
stock rim or aftermarket rim??
have u checked the alignment for toe?? should be 0.0 toe (center)
(NFS Underground)
Posted 16 May 2013 - 03:11 PM
QUOTE (rallychamp @ May 15 2013, 11:21 AM) <{POST_SNAPBACK}>
Wah! Exora OE toe is zero? so camber should be slightly negative?
Usually FWD will have slight toe out...
