Posted 24 April 2013 - 12:53 PM
Sorry of my "flog under the coconut shell", what is PADT stand for?
I just sent my car to the nearest service centre for checking just now, the technician said he had serviced the throttle body and re-tune the engine... I have to observe it for a few days and see whether the problem has been completely solved or not...
proton advance diagnostic tool.
so how was you car behaving now bro ?
jasondotcom
Posted 10 May 2013 - 10:44 AM
i got the similar experience.. but it was caused by my aftermarket throttle controller ( e-throttle ) it went into save mode during spirited driving and sluggish. engine check light on. stop the car turn off. restart the car a few moment back, it went back to normal..
our pedal is drive by wire sensor. maybe the sensor got problem. have you do the resetting of the pedal ( they call it pedal respond ) before ?
you can try to reset throttle body your self. my friend have a guide buts it is in BM
http://eilarazi.blog...ottle-body.htmlfor the pedal respond. my mech adjust the pedal setting so it will have more responds ( speed up the signal from pedal to ecu ) when you step on the gas pedal. its kindda like you press 10%, its told the ecu that you throttle to 20% instead of the normal setting that you press 10%, you get 10% respond.
Bro, Proton do pedal response tuning or not??? How much the charges?
rallychamp
Posted 10 May 2013 - 12:07 PM
one of my friend kena even worse...engine died itself whenever the engine like.....
have to change ecu since PDT scan results no error code....
bangkura
Posted 25 September 2015 - 11:16 AM
bangkura
Hi dear forumers,
Today, I was as ussual drove my Persona to work. After I reached the highway, I suddenly felt that my car was slow down gradually. Then I stepped a bit deeper to the throttle, but useless, the throttle was no response. I drove my car to the most left lane and than stop it, then I stepped again the throttle. The RPM went up but very slow, I tried to accelerate my car with full step on my throttle but just able to speed up to 40km/h. So I decided to switch off my engine, after a few while of "engine cooling down" I restart my engine again then everything went back to normal...
What's going wrong with my car? Do you face the same problem as mine before? Thank you
The same happen to me.. This morning I start my engine, the check engine light is on, but my throttle no response, rpm if I step only goes until 1500rpm.. Now waiting for Proton Tow Truck.. "sigh".. I wonder what is the problem..
