dear all,
can anybody advise how much cost to install PE fog lamp?
have survey with acc shop and price around rm120-rm200. is this ok or expensive?
acc shop also said they need to take out the front bumper in order to put bracket and install the fog lamp, is this true?
is it ok to pull out the bumper coz as you all now acc shop people when then pull something out from your car, it will not be the same after then put it back in(hehehehe...no offence.this only base on my experince)
thanks for your advise
Fog Lamp
jfy1774
, Nov 16 2012 10:36 PM, 3 replies to this topic
Posted 18 November 2012 - 08:20 AM
QUOTE (jfy1774 @ Nov 16 2012, 10:36 PM) <{POST_SNAPBACK}>
dear all,
It's not strictly true that you have to remove the front bumper in order to fit/replace the fog light bracket,
but it does make the job very much easier and is the better way of doing it.
If they're careful enough, then they should'nt do any harm to the car by removing/replacing the bumper.
'Do average things - get average results'
Posted 19 November 2012 - 03:03 PM
QUOTE (slushmatic @ Nov 18 2012, 08:20 AM) <{POST_SNAPBACK}>
thanks slushmatic for the advise.....
Posted 12 March 2013 - 09:02 AM
If I'm not mistaken, the cost was around RM250 (3 months ago) in JB. It is not required to do wiring, because is already done by Proton. All you have to do is take out your front bumper and install the bracket that come together with your fog lamp, then by-pass it at centre console. So when you switch on your headlamp, the fog lamp will also switch on automatically (of course you can install a switch to switch it off also).
For your information, fog lamp is restriction in Singapore (switch on only on poor weather).
