Kia Rondo 40,000 Km Service - Need To Replace Auto Transmission Fluid?
Posted 11 September 2012 - 08:42 AM
Can this be changed at 50k km or higher mileage ? because I have been driving my Rondo quite smoothly without abrupt changes of gears with gentle throttle too.
Posted 11 September 2012 - 08:53 AM
Bro,
If your Rondo is still under warrantly, then no choice have to change lah. My Rondo also appoaching 40,000km. Warrantly ends on Dec 2012.
Posted 11 September 2012 - 12:24 PM
It is not about gentle driving , it is more towards prolonging lifespan of the gearbox. Some people change it at 20k.
Posted 11 September 2012 - 02:02 PM
+1
Gearbox is like one of important organ for human body and require high preventive maintenance because if anything happened the cost to rebuild or replace a gearbox is very costly. I would advise owner to follow the 40K interval ATF fluid change religiously.
Posted 11 September 2012 - 04:56 PM
Yes, this is a very important part. Please change your ATF on every 40k KM basis.. Many automatic gear box fail due to lack of AFT fluid maintenance awareness..
Posted 11 September 2012 - 07:37 PM
Posted 12 September 2012 - 10:01 AM
I usually change mine between 20 ~ 25k kms.. more so especially if you drive in start-stop city traffic. Make sure you are using SPIII ATF. Not others. FYI, the SC used the wrong type during the first change and I have to flush the the gearbox elsewhere!
Posted 12 September 2012 - 11:29 AM
Hi, Bro
I was advised by the AT specialist to follow the 40K interval ATF fluid change . I had my Rondo do the complete ATF flushing by machine using Hyundai ATF SP III 4L x 2 cost me RM150 & machine flushing charges at RM 50. PM is essential for AT, morever I think the cost of doing it is quite reasonable.
My Sharing
Posted 12 September 2012 - 01:27 PM
Appreciate your sharing !! This is automatic transmission fluid which indeed is important for power transmission.
Posted 12 September 2012 - 01:31 PM
1. By the way, why x2 ? The SC quoted me 4L only, and did not mention x2.
2. And machine flushing means engine flushing (draining off together with the old Engine Oil) ? Please enlighten me, thanks so much !
My Sharing
