C5 Abs Fault
enaizi
, Jun 18 2012 12:04 PM, 7 replies to this topic
Posted 18 June 2012 - 12:04 PM
My 2002 C5 have a ABS Fault error. What does it means, where can I get it fixed and how much would it cost?
Any help appreciated
Posted 18 June 2012 - 12:37 PM
There is a bad news and not so bad news.
Bad news is your abs pump oredi kaput. Actually the culprit is the ABS ecu but the ecu came together with the pump. It happend to me many moons ago but I only get it repair last 2 week after the ecu finally disable my gearbox and suspension.The car must be plugged in with a diagnostic computer to check the actual fault. The 2nd hand abs pump cost me RM1200 + RM300 for diagnostic and labour. A potong kereta shop in ampang quote me RM2000 for the abs pump (tis shop really potong kepala). Last time they quote me RM300 for the windscreen washer water tank. Last week I sold the car and live happily ever after.
Huarrrrgh
Posted 18 June 2012 - 12:41 PM
Few possibilities:
1. ABS sensor connection
2. ABS sensor
3. ABS pump
My experience on C3: The #1 is easy. Use your hand to access the sensor assembly either thru the engine bay or tyre (you need to turn the steering wheel). Then go for a short ride, if the ABS fault bling again during cornering, next is to replace the sensor.
Historically for C5, quite common the rootcause is due to ABS pump.
2. ABS sensor
3. ABS pump
Posted 19 June 2012 - 04:23 PM
My 2004 C5 had the same problem ...
At first it was intermittant, then after a few months it became permanent.
Tried adjusting/cleaning the sensor : no effect.
Did a diagnostic check : culprit was was the ABS module.
Price check: brand new RM6k, used RM1.5k (but difficult to find).
No one could repair the module, and resetting the ecu only lasted a week before the lights came on again.
So i did what lingomalingo did - sold the car.
And got me a new C5
And got me a new C5
Posted 20 June 2012 - 09:46 PM
If it is really the ABS ECU causing the problem, you can try repairing it . There is one AW forumer here by the nickname kiamtiap who specialises in repairing the electronic module aka ECU. Just search for him in Proton or Volvo section and you shall find his h/p no. His charges is cheaper than a 2nd hand ABS pump I think.
Regards.
Regards.
Posted 22 June 2012 - 06:21 PM
Hi leongts,
I did contact kiamtiap - according to him the C5's particular brand of ABS module can't be repaired
Posted 28 June 2012 - 03:02 PM
QUOTE (lingomalingo @ Jun 18 2012, 12:37 PM) <{POST_SNAPBACK}>
so now, what car u drive?
r u saying that, don't by C5?
tq
Posted 30 June 2012 - 09:31 PM
QUOTE (mzulfekar @ Jun 28 2012, 03:02 PM) <{POST_SNAPBACK}>
tq
tq
C5 is actually a gud car but as it get older the problem also become harder n expensive to take care. At least im happy now that i hv no longer big burden in my head.
Now still searching for the replacement. I am thinking of getting the old 200E or C200. Will see that after raya.
Huarrrrgh
