Currently i am on stock absorber coupled with proride spring.
The spring is good but the OE absorber cant keep up with the spring.
I might go for proride sport absorber if my hand is still itchy...hehe
On corner it is good but mind u i have 3 U bar installed and it adds to the fun.
EVen with the bars alone without the proride spring, my car felt solid.
If u are driving FL or FLX u will feel that the suspension setup is a littler bit firmer than 1st batch BLM.
It s not much but u can feel it.
If u are driving FL then why not just get yourself some UR bars. Its a one time investment.
This way u will have firm feel without compromising comfort feeling at all.
mine is 09 blm btw and so far i have only installed UR front strut bar,initially i wanted to install proride but i came across a couple of negative comment that the spring and absorber doesn't last long and within a year kong!
btw may i know which bars have u installed that made the ride solid,currently i'm planning on getting a set of GAB sport springs to be paired with IMP propex sport absorbers.Still deciding whether it's a wise choice.
if i choose proride both spring and absorber it will be a whole lot cheaper but the reliability which i'm worried about.since you're using proride how has it been so far and is it true that the absorber will worn out fast?
Same time manage to get a set of suspension from a buddy who stop modding his Mitsu
Front
Rear
Using them for about 2 weeks, still have not got time to readjust the height and play around with the spring tension and damping rate.....
hahaha....poison!!!
