my one since Nov 1997 AE111.
initially after around 170k km just replaced timing belt, water pump, flushed radiator, top and bottom engine gasket leaked and replaced, atf filter, fuel filter, 4 tyres, 4 shocks and spring, battery, steering rack (be careful always leak, replaced with chopped), drive shafts (always leak the rubber boot, if whole shaft gone, replaced with chopped). engine mountings.
then progressively.
replace to vios second hand sport rim, maintain 14".
air-con compressor new one, full service air-con system.
replaced the whole exhaust except maintain the original extractor due to weird loud noise coming out and some crack at the bullet as improper modified by the previous owner.
recently replaced bushings for front control arm, front and rear sway bar, rear trailing arm, front & rear stabilizer link, repaint external.
now run like new. just need to on-time service everything the usual oil, filter, belts, front brake pad, rear brake shoe, brake fluid change.
the cobra alarm still functioning well. the ECU so far so good. O2 sensor still ok. fuel consumption can maintain 13.x-14.x km/l when highway cruising. except trap in traffic jam, then drop to 10-11.xx km/liter.
am so reluctant to sell though some mechanics who have test-drive asking if i wanna let go.
thanks for another success story, well, have u consider the durability of the car body? after being faithfully serving u for 15 yrs, i guess the engine can go for another many years, will the car body be as faithful as the engine?
now i am getting closer to get for myself an yr96 SEG from my mechanic friend after all these testimonies
