OK, thanks - will check if it is capacitor failure...
I replaced my high pressure power steering hose - no more leaks after that.
BTW, I found that the original front brake pads to be very long lasting - seldom needs replacement. Just regular servicing... But rear drum cylinders tend to leak after a while, so need replacement.
this is one reason why the japanese has come up with electronic power steering (EPS) that is not using hydraulic anymore. no more pressure hoses, no more pump, no reservoir - definitely NO LEAK.
cars like new myvi, honda city, new vios, prius.. they all using EPS. no need drive belts too!!
just a bit curious ur 20 yrs old SEG can still climb up to Genting or Cameron Highland? coz now i am really seriously considering to buy my mechanic friend's yr96 SEG, also in good condition, if i buy it, plan to make long distance trip from PG to KL, or Melaka, is it advisable to stretch that far? thanks.
based on reliability it can, should not be much problem even though at 16 years old, need a health check regularly. as it was owned by a mechanic, has some good faith.
personally i will have 2 issues with the 96 SEG
1. cabin size which is on the small side
2. suspension which is comfortable but doesnt like to be pushed in corners at all. the car will suffer from roll badly.
