a little bit confuse, same engine same VT2... but got lag trotller response?
That was what I felt, and it took me by surprise. It is slower than the turbo version for sure, but not as bad as I expected it to be. Certainly more responsive than what I remembered of the Saga FLX SE.
what about soundproof compare wif saga FLX se? and pick up also... with my current salary i want to buy saga FLX SE 1.6.
should i proceed?
The Preve is definitely better insulated than the Saga. On whether you should buy the FLX SE or not, I suggest you test drive the car first. I personally found its throttle response to be slow and its brakes soft, so unlike most Protons, this is not the enthusiast's choice.
However, if you're looking for a compact sedan with decent boot space and passenger room for four pax, and affordability is a key consideration, then the FLX SE will be a frontrunner choice.
Question ultimately is what are your needs and wants?
